A/C cutting in and out on 00 V6 - Mustang Evolution
Old 08-18-2006, 05:33 PM   #1
The A/C occassionally cuts out under throttle on a 00 V6 Mustang. Any ideas?
04 WRX - Tuned on Enginuity
MF-DIF is offline   Reply With Quote
Old 08-18-2006, 06:46 PM   #2
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
Re: A/C cutting in and out on 00 V6
Is this part throttle or like 75%-WOT? I know with some cars when going up hills or there's a high demand on the engine the AC will slow down the compressor so the engine can get maximum power.
It could be a combination of that and maybe you're a little low on R134a. Not uncommon for a car that's almost 7 years old.
What speed are you going when this happens? What's the ambient air temp? any other relative information is helpful...
99 Cobra: flowmasters, 18x9.5 cobra R's, soon to be tuned and geared. daily driver
99 V6:in avatar, Mac Cai, true duals/flowmaster 40's ,UDP, custom tuned, bullitt suspension 18" wheels...taken by mother nature
I_luv_HP&trq is offline   Reply With Quote
Old 08-18-2006, 07:24 PM   #3
Most cars nowadays cut off the a/c compressor at wot, pretty normal.
Old 08-19-2006, 05:43 AM   #4
It's more like 40% throttle. Not at WOT. I don't know if its the refridgerent, this problem seems linked to engine load.
Old 08-19-2006, 10:42 AM   #5
Hm...so it's like the engine is bogging down and the a/c cuts out. Sounds like there's something clogging up, when's the last time you changed the fuel filter?
Old 08-21-2006, 07:43 AM   #6
On 99-00 v6 the ac cuts out when at WOT. On 01+ it stays on. This is a parameter in the EEC that I can tune.
Justin Starkey
2007 Shelby GT500 705RWHP/708RWTQ
2000 Mustang 3.8 A4 TT 450RWHP/475RWTQ 10.996@127 17psi stock 3.8
2006 F250 CC 4x4 6.0L 14.3 @ 93
2006 Mustang 4.0 M5 Vortech 13psi 395RWHP/374RWTQ wife's car
justin00stang is offline   Reply With Quote
Old 08-22-2006, 07:30 AM   #7
I'm not at WOT when this happens. The motor does not lug either. It happens when you maybe put down 1/2 throttle. It's spuradic. The car has 65k on it.
Old 08-22-2006, 08:39 AM   #8
Right. Could be a bad clutch or low on r134a.
Justin Starkey
Engine cutting out? nofeargt 1996-2004 Mustang GT 13 01-25-2010 08:55 PM
cutting springs? BlackSix Pre-2005 V6 Mustang 17 11-24-2008 09:50 PM
cutting springs.. x99xstangxx Pre-2005 V6 Mustang 11 11-07-2007 07:03 AM
Engine cutting off rydog General Car Discussion 7 08-10-2006 02:57 PM
cutting cats auto6banger Pre-2005 V6 Mustang 37 12-31-2004 11:17 AM
04:28 AM
