4.10 gears - Mustang Evolution
Old 08-19-2006, 12:17 PM   #1
4.10 gears
Everybody says that 4.10 gears are really bad in gas but exactly how bad? Is it as bad as having a GT or worst?
I have a automatic 2004 V6 and most of my driving is in the city???
if i died before i wake up please let me know
strike1980 is offline   Reply With Quote
Old 08-19-2006, 02:35 PM   #2
Re: 4.10 gears
If most of your driving is in the city you might actually see an increase in gas mileage if you can keep your foot off the little right pedal.
Old 08-19-2006, 03:03 PM   #3
maximus's Avatar
Re: 4.10 gears
ill be getting mine put in on tuesday, ill keep ya updated. i have a 03 v6 auto
maximus is offline   Reply With Quote
Old 08-20-2006, 01:19 AM   #4
Re: 4.10 gears
Thank you
Old 08-20-2006, 01:31 AM   #5
Re: 4.10 gears
gas mileage does not get hurt too bad, just get them. Although it makes it alort harder to resist flooring it often. Remeber you will need a tune if you have an automatic to correct yoru speedometer due to the gear change.
Old 08-20-2006, 08:31 AM   #6
slvr2000stang's Avatar
Re: 4.10 gears
That is correct. On 99+ autos you have to get a chip or tuner to compensate for the gear change.
On a manual you can get away with a speed-cal adjuster.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 08-20-2006, 11:47 AM   #7
Danger Dude's Avatar
Re: 4.10 gears
Here is the deal 4.10's are cool but in the real world unless you are a track dog you really wont notice the difference between 4.10's and 3.73's You say most of the miles you use is City then you will be OK but with gas prices as high as they are you will notice the drop in fuel mileage with 4.10's at 75mph on the interstate. basically you will cut around 40 miles off per tank. It is all in what is important. It is your car and you decide.
4.10's are cool but 3.73's are not to shabby either.
Old 08-20-2006, 02:41 PM   #8
Re: 4.10 gears
I was thinking of the 3.73 but people the get them always regret getting them instead of the 4.10
Old 08-20-2006, 02:45 PM   #9
bbunt302's Avatar
Re: 4.10 gears
I'd get the 4.10s. I had them in the '90 for a while and wish I would never have gotten rid of them. The small trade-off in mileage is worth it for the extra punch in my opinion.
Scary stuff.
Old 08-20-2006, 05:35 PM   #10
Re: 4.10 gears
I started with 3.73's and now have 4.10's Should have made the big jump first.
I was lucky and a friend needed 3.73's so I was able to resell them.
2000 Vert 4R70W
Old 08-20-2006, 05:44 PM   #11
Re: 4.10 gears
I beg to differ, I have driven my friends car with 3.73's (stick) and my car has 4.10's (stick). My car seems quite a bit quicker, we both have the same other mods too ebay cai, and magnaflows.
Old 08-20-2006, 05:53 PM   #12
Re: 4.10 gears
In daily driving I noticed a very measurable difference.
2000 Vert 4R70W
Old 08-31-2006, 02:37 PM   #13
Re: 4.10 gears
how much do those cost + install?
dew4man is offline   Reply With Quote
Old 08-31-2006, 02:42 PM   #14
Re: 4.10 gears
You are also forgetting and auto has worse gearing compared to a manual tranny'd mustang. The final gear ratio (calculating though the transmission) as you go though the gears will be closer to a manual with 4.10s compared to 3.73s. I would go 4.10s dont fear the gear.
Gear install is a tricky thing... the shop needs to know HOW to do it. You simply can not just bolt them up and go. They have to be installed to a specific spec including but not limited to: backlash, pinion depth, crush sleeve set right, pattern matching, etc. If a shop does not know how to do those things or even what they are I wouldnt let them touch it. Also, its far better to pay more for a better job than save a little and wind up having to redo EVERYTHING due to you didnt get the job done right. Just a bit of advice I fell victim to myself.
Old 08-31-2006, 03:32 PM   #15
Re: 4.10 gears
Really??? Kirk you are a lead foot!!! Actual normal driving should actually be no different except for a faster rise in RPM
Old 08-31-2006, 03:41 PM   #16
Re: 4.10 gears
Street racing again???? As I said in normal driving is not as noticable. On the track that is different. As I said before if you are not going to go to the track a lot I would go with cheaper fuel and get the 3.73's. If you are going to go to the track get 4.10'. Most of you are young and not nearly as sensible in this approach. Consider the long run in a couple of years when fuel is $5.00 a gallon.
Old 08-31-2006, 05:27 PM   #17
bbunt302's Avatar
Re: 4.10 gears
Street racing again???? As I said in normal driving is not as noticable. On the track that is different. As I said before if you are not going to go to the track a lot I would go with cheaper fuel and get the 3.73's. If you are going to go to the track get 4.10'. Most of you are young and not nearly as sensible i this approach. Consider the long run in a couple of years when fuel is $5.00 a gallon.
I could notice a difference in normal driving when I went to 4.10s to 3.73s. That's a pretty big jump... Hence, a lot of people are starting to use the 3.90s which are a good compromise.
Scary stuff.
Old 08-31-2006, 05:37 PM   #18
Re: 4.10 gears
How the hell do you notice it in NORMAL driving as in normal city driving unless you lead foot and really so what if there is minimal notice. For the reality of it is if you dont go to the track or street race then it is just a choice of mileage.
Once again it is up to the individual and preference. I have never said he should get either I just throw out options and what is his desire to improve. I also want to point out that will gas might be in a slight decline as of right now the world continues to use more gas and increased gas prices will have an effect.
Just something to think about
Old 08-31-2006, 05:47 PM   #19
bbunt302's Avatar
Re: 4.10 gears
I consider it pretty normal to stomp on the gas every once in a while, especially getting out on the highway. I don't drive around like Speed Racer all the freakin' time like some, but what's the point of spending money on performance parts if you aren't going to have a little fun with them?
Scary stuff.
Old 08-31-2006, 06:33 PM   #20
Re: 4.10 gears
Never said that stomping is not fun. I do it all the time but are you trying to say 3.73's are not fun. If so that is a rather asinine statement.
We here are trying to give people good information and OPTIONS!!! If we are going to be like the other mustang sites and be Nazi's about what we suggest we might as well just move over there with those nimrods.
But alas we are different and opinions are good and options are even cooler. We here seem to be heading into that rutt. I will not assimilate to one option or opinion. There are to many good products or options and reason for the differences.
Old 08-31-2006, 07:31 PM   #21
bbunt302's Avatar
Re: 4.10 gears
Never said that either stomping is not fun. I do it all the time but are you trying to say 3.73's are not fun. If so that is a rather asinine statement.
To the Thunderdome!!!
Seriously though, I did not, nor will I ever say 3.73s aren't fun. I just said that I could tell a difference between them and 4.10s in every day driving, which I could. I personally would kinda rather have the 3.73s for a daily driver. Kinda. It really depends a lot on the car and the driver too though.
The OP has an automatic V6. Lower gears are more important to an automatic V6 than they are to a ~300rwhp 5.0 with a T5. Which is why I recommend he go with the lower gear. Not to mention the fact that he said most of his driving is done in the city. This means the difference in mileage for him will be pretty negligible.
Scary stuff.
Old 08-31-2006, 08:38 PM   #22
Re: 4.10 gears
I would agree
Old 08-31-2006, 11:38 PM   #23
Re: 4.10 gears
My foot is a bit heavy, I would definatly notice the difference in normal driving.
Old 08-31-2006, 11:39 PM   #24
Re: 4.10 gears
Me? No, never.
Just spirited driving with friends.
Old 09-01-2006, 05:56 AM   #25
Re: 4.10 gears
Me? No, never.
Sure you're not. Your atheist *** is going to hell????
Old 09-28-2006, 01:24 AM   #26
Re: 4.10 gears
last questions about gears. if i get 4.10 do i still be able to s/c my car
and if i get 3.73 will i feel a big difference from stock gears
Old 09-28-2006, 06:03 AM   #27
bbunt302's Avatar
Re: 4.10 gears
Yes and yes.
Scary stuff.
Old 09-28-2006, 09:05 AM   #28
maximus's Avatar
Re: 4.10 gears
get the 4.10's, i do alot of highway driving everyday to and from work and and a bunch of city driving and i still get about 21 mpg:woo: ...and if your going into your rear end, get the t-lok. bcuz your going to be spinning that single wheel alot if you dont get the t-lok. i cant keep track of how many times a day i am making a sharp turn from a stop and the tires break loose a little and im not even on the gas that much, so imagine how the single wheel will react...just my $.02
Old 09-30-2006, 07:49 PM   #29
megax29's Avatar
Send a message via AIM to megax29 Send a message via Yahoo to megax29
Re: 4.10 gears
I'm also considering going w/ different gears and I was wondering if someone might know what the rpms would be if I were going 70 mph on the freeway w/ 3.73s and 4.10s. Maybe someone that's got them can try it out for me. My car going 70 is at 2100 rpms. When I hit the O/D it goes up to 3100, I think, but that's too much. I'd like my car to cruise around 2.5k or 2.6k.
V6 Midnight Black
CAI w/ K&N Filter, Tokico Complete Suspension kit, Single Flowmaster w/ turndown, GT rear sway bar.
megax29 is offline   Reply With Quote
Old 09-30-2006, 07:53 PM   #30
maximus's Avatar
Re: 4.10 gears
if you want your car to cruise around at 2.5 idk if you want to go with gears at all. i cruise at around 75-80 and the rpms run at 3k and higher. and with over drive...well lets not talk about o/d...
Old 10-01-2006, 05:05 PM   #31
Re: 4.10 gears
Driving around the city I get bad mialage, but that's from my driving, but when I was moving up to college I got 22-23 mpg cruising at about 70-75mph.
Intermision is offline   Reply With Quote
Old 10-01-2006, 05:23 PM   #32
rocknbronco's Avatar
Re: 4.10 gears
I would go for 4.10s
Mustang wanted for here...
rocknbronco is offline   Reply With Quote
Old 06-04-2008, 06:33 PM   #33
raziejonjon's Avatar
Re: 4.10 gears
I have a 4.10 in my 1991 5.0....and my speedometer is all out of whack. I have heard different things, from buying a pack of gears and by trial and error figuring out which one you need, to having to mess with the tranny. Anyone know by experience what to do?
raziejonjon is offline   Reply With Quote
Old 06-04-2008, 09:50 PM   #34
Scut95's Avatar
Re: 4.10 gears
you can get the black 6 gear tooth for the output shaft and then get the 21 tooth for the speedo cable.....that will get your speedo back to stock for 4.10's......i have the 6 tooth and an 18 tooth for my 3.73's and my speedo is dead on.
NEED HELP WITH GEARS!! Motive 4.10 gears? Cant find ford racing? Camaro Eater Pre-2005 V6 Mustang 4 06-23-2010 10:57 AM
3.73 gears tim11 Pre-2005 V6 Mustang 5 10-25-2005 08:21 AM
4.10 gears powerhungry966 Pre-2005 V6 Mustang 7 10-23-2005 06:53 PM
gears 8.8 or 7.5 strike1980 Pre-2005 V6 Mustang 5 07-31-2005 11:05 PM
Factory Gears Vs. Racing Gears tire Pre-2005 V6 Mustang 0 07-21-2003 04:02 AM
09:41 AM
