Need help with cooling system - Mustang Evolution
Old 08-28-2006, 01:42 PM   #1
Dman's Avatar
Send a message via AIM to Dman
Ok so here is my problem my 95 V6 mustang temperature gauge has been acting up recently. When I drive in town under normal driving conditions the temperature gauge would stay in the middle . as soon as i would come to a complete stop it just jumps inbetween the M and the A of the temp gauge . It also does this when I accelerate hard,but as I start to drive normal agian it slowly moves back to normal. ok now If get on the highway and i am driving at a constant speed the temp gauge needle starts to slowly move down inbetween the O and R .
I have changed my water pump and thermostat and it still does it. Help please
ID:	14280   Click image for larger version
Dman is offline   Reply With Quote
Old 08-28-2006, 02:11 PM   #2
Zim
You want to **** me?
Zim's Avatar
Re: Need help with cooling system
have you checked to make sure your fan is turning on when it reaches operating temperature?
I like toys
Old 08-28-2006, 02:42 PM   #3
i would buy a gauge to make SURE the temps are raising/lowering it might just be the stock POS gauge.
Old 08-28-2006, 06:20 PM   #4
Zim
Zim's Avatar
its probably not the guage, maybe the sending unit though :dunno:
Id make sure the fans coming on, if it is... take it to a mechanic to check the temp sending unit.
I like toys
Old 08-28-2006, 07:05 PM   #5
Mine jumps down like that while cruising, I could probably change my fan settings to make it stay off a little bit longer and run a bit warmer. It is good advice to get a gauge that actually reads correctly however.
Old 06-16-2007, 10:35 PM   #6
Send a message via AIM to V6Polish
Sounds like the same exact problems that I am currently undergoing with my mustang. I have changed my thermostat as well and still have these problems. Have you figured anythign out yet? Being that this is a very old thread?
V6Polish is offline   Reply With Quote
cooling system flush - Help!!!- 00stang3.8 Pre-2005 V6 Mustang 2 11-11-2007 11:10 PM
Burping the cooling system? I_luv_HP&trq General Car Discussion 2 09-06-2006 09:55 PM
cooling 9899musl 1996-2004 Mustang GT 0 03-14-2006 05:24 PM
Cooling issues lightning 1996-2004 Mustang GT 5 10-12-2005 10:12 AM
My Cooling System 04MonteSS The Bar 12 07-30-2005 03:50 PM
11:25 AM
