Loss Torque With Duals...Help!? - Mustang Evolution
Old 08-30-2006, 08:35 AM   #1
greaser's Avatar
My '07 V-6 Pony is sick. I put Magnaflow dual GT cat back (not magnapacks) with "X" pipe and I've lost the snap she had in third before the install. No doubt about it. Magnaflow now tells me I should have kept the "Y" pipe set up to avoid loss of back pressure. No other mods. The tech said a CAI won't cure the problem and I won't take the chance on an SCT tune that may give Ford a chance to void my warranty. Need some help guys...thanks so much.
BTW really sounds strong, not loud at idle and not much more drone than stock, but when I get on it....WOW! P.S. Thanks for the advice on oil use...Mobile 1 all the way.:woo:
2008 Mustang Bullitt*Brenspeed Performance Tune
Pype's Violators Axle Back
http://www.youtube.com/watch?v=xRIjQXCVhto
greaser is offline   Reply With Quote
Old 08-30-2006, 10:08 AM   #2
Re: Loss Torque With Duals...Help!?
the car may feel slower but it may in fact be faster, you just moved your power band up~ maybe to far~ if you keep 2.25 inch pipe on your duals you should be fine.
Old 08-30-2006, 10:08 AM   #3
Danger Dude's Avatar
Actually you lose very little torque. Now that the car breaths and exhales better the torque has shifted up the powerband. I would consider getting a CAI and some gears then get a SCT chip. I would not worry about the snap you seem to be missing in third. Are you street racing or going to the track???
Old 08-30-2006, 10:14 AM   #4
Herbstang's Avatar
Did you go to 2 1/2 pipes ?? Just a thought When I installed the dual system on my 04 the power and torque went from low end to mid range
A common misconception is that the larger the diameter, the better the system. But, bigger isn't always better. Systems that are too large in diameter can actually hurt low-end performance.
keep in mind that if you increase the pipe diameter too large, then you have a much larger area the exiting exhaust must cover. If the engine pushes out "X" amount of exhaust, and the exhaust is too large and the exhaust exiting the engine cannot fill the pipe, it cools quickly, slows down, and causes a restriction also. The hotter you can keep the exhaust, the faster and easier it flows. This is one of the reasons why an off-road pipe loses some low-end but gains more top-en
Old 08-30-2006, 12:00 PM   #5
greaser's Avatar
Thanks guys, you always come thru. The exhaust for the S197 05 to 07 Mustang's are using 2.5 inch pipes (at least mine was) and that's what Magnaflow sent in the cat-back kit. I must say (it's a 5 speed stick shift) she still moves out pretty fast, I just noticed while cruising in traffic in third I used to be able to tap the gas pedal and the front end would imediately raise up ready for action and now that it no longer does this I thought something was wrong. But hearing about the power band shifting higher makes sense and I really don't want the hassle and expence of redoing my exhaust all over. If you guys seem to think everything is normal, I might live with a little less torque in the lower rpm band until my warranty concerns are over and I get what I really want as far as mods. An SCT bamachip tune, AEM Brute Force CAI, 3.73 gears w/TLOC and a better shifter-missed third twice..hate that when it happens. Thanks Guys
Name:	Rear GT Magnafow 1.jpg
ID:	14320   Click image for larger version
Old 08-30-2006, 01:08 PM   #6
Herbstang's Avatar
I Hear ya !! I blow my warrenty 1 months after I got my 04 first came the duals and short throw next the SCT chip,UDP and t-lok 3:73
If you don't do alot of highway travel you might want to look into 4:10 Wish I had got the 4:10
Old 08-30-2006, 01:26 PM   #7
greaser's Avatar
Unfortunately, I've got an 80 mile roundtrip commute each and every day. Another good reason I decided to go with the V-6.
Old 08-30-2006, 01:52 PM   #8
2 more mpg ftw! lol
Old 08-31-2006, 07:03 PM   #9
I don't know anything about the SCT chips but if you use a diablo preditor computer it saves the factory tune and you can set up 3 of your own if anything was to ever happen to the car you just set the stock tune back and ford will never be able to tell the difference. Actually I just have a totaly stock v6 and with putting a CAI and the preditor in it will give me almost the same hp and tq as a gt
Stupid speed limits!!! :( Stupid tickets!!!! :mad: PANTERA, PEDAL TO THE METAL AND DRIVE IT LIKE YOU STOLE IT!!!!
BNUTS
Bnuts is offline   Reply With Quote
Old 08-31-2006, 08:31 PM   #10
All chips have the ability to have several tunes. SCT happens to have the best database of Ford cars and a great network of local tuners with access to that database. But in reality a good tune can use any chip and do well. SCT just happens to be the best for Fords period.
Old 09-02-2006, 02:43 AM   #11
Thomas91169's Avatar
on the butt dyno maybe. real world, no.
you might gain a few ponies and some better throttle response, but as far as gains over the entire spectrum, maybe 10hp to the wheels. and that would include things like cai, full headerback exhaust, udp's, plenum/tb, dynotune for the whole setup, and this is concerning a GT.
whenever you decrease the backpressure on a naturally aspirated car, you move the torque curve up. backpressure aids in the scavenging of exhaust gases which is what helps the bottom end of the spectrum.
-Thomas-
Old 09-02-2006, 10:01 AM   #12
No it said BWH not from the engine dyno but BWH. I've got 210hp and 240tq a CAI can add a bit and the chip will add a good amount the gt's only have 300hp so its not like its much to have to gain to catch up
BNUTS
Old 09-24-2006, 08:35 PM   #13
Rick0636's Avatar
CAI does help! I have factory duals, from a stock GT, the left side pipe is custom made, used the right side stock one. The stock system is 2.5 inch, why go smaller than stock? I didn't feel any torque loss with my duals at all.
99-04 v6 true duals (help!) CHILE10_STANG Pre-2005 V6 Mustang 14 06-22-2009 08:04 PM
True Duals Taywi Classic Mustangs 10 12-09-2006 03:30 PM
no duals merlyn041 Pre-2005 V6 Mustang 10 08-02-2003 05:34 PM
Duals or Suspension? Killer Squirrel Pre-2005 V6 Mustang 1 05-13-2003 03:36 AM
08:53 AM
