crunches and squeaks - Mustang Evolution
Old 09-04-2006, 10:12 AM   #1
i have a 2000 automatic v6. when i turn my steering wheel, it squeaks and crunches really loudly underneath? what is this?
stang00 is offline   Reply With Quote
Old 09-04-2006, 12:20 PM   #2
Re: crunches and squeaks
Sounds like a power steering pump to me.
Old 09-04-2006, 03:07 PM   #3
it might also be the tie rod/ ball joint/ strut area as well. Does it sound like it comes from one of the wheels? Get a friend to pin point its location while its doing it.
Old 09-04-2006, 06:16 PM   #4
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
If it's a tie rod end then he would hear it going over bumps in the road as well. If it's only when turning then i'd think it's his ps pump like brent said.
Easiest thing for you to do first is check your power steering fluid.
99 Cobra: flowmasters, 18x9.5 cobra R's, soon to be tuned and geared. daily driver
99 V6:in avatar, Mac Cai, true duals/flowmaster 40's ,UDP, custom tuned, bullitt suspension 18" wheels...taken by mother nature
I_luv_HP&trq is offline   Reply With Quote
Old 09-05-2006, 10:55 PM   #5
megax29's Avatar
Send a message via AIM to megax29 Send a message via Yahoo to megax29
I have the same problem when I break and the car bends over, when I accelerate or when I hit a bump. Do I need to replace my struts? I'm hoping not to since that's a $500+ upgrade.
V6 Midnight Black
CAI w/ K&N Filter, Tokico Complete Suspension kit, Single Flowmaster w/ turndown, GT rear sway bar.
megax29 is offline   Reply With Quote
Old 09-13-2006, 08:50 AM   #6
I checked my power steering fluid..its good. In the range it should be. Its a really loud squeaking sound when I turn the sterring wheel either right or left. How can I check to see if my PS pump is bad?
Old 09-13-2006, 09:03 AM   #7
MonteCitan's Avatar
is it a constant squeak the entire time you're turning the wheel?
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 09-13-2006, 09:06 AM   #8
yes. either way i turn the wheel, it squeaks the entire time. I tried turning the engine off and turning the steeering wheel to see if it still made the noise and it does?
Old 09-13-2006, 10:26 AM   #9
I also have a thumping noide under the front of my car? I can feel it in the gas pedal and the passengers can fel it under their feet when they are sitting in the front passenger seat? I can hear it thump thump thump while I drive? What could this be? i was told soemthing about my wheel bearings?
Old 09-13-2006, 10:52 AM   #10
MonteCitan's Avatar
any chance you can have someone turn the wheel? (car off, in park/gear with the ebrake on so they don't run you over..) lie under the front and listen around the steering rack? There have been problems with where the rack bolts go through the subframe drying out, and making noise. also be sure to listen around each tie rod (the parts that come out of the rack that go to the wheels..)
If you don't hear it from under the front of the car w/the car off (which discounts the power steering pump) start listening under the dash, where the steering shaft goes through the firewall
Steering squeaks NorwegianMustang Pre-2005 V6 Mustang 1 07-31-2003 11:12 PM
03:13 PM
