P & P Question - Mustang Evolution
Old 05-17-2010, 08:17 PM   #1
rinfield2004's Avatar
P & P Question
Hey whats up. I am to be starting on my motor build tomorrow. I'm 2wks behind my original start date, but w/e. But my question is this....while I have my motor apart and building my bottom end. I am going to p & p my heads, upper, and lower intake. So, about how much of a power gain am I to expect?
I'm running a supercharged set up. Currently at 8lbs of boost. then moving to 14lbs of boost here soon. If this helps any.
I look forward to hearing from you guys.
rinfield2004 is offline   Reply With Quote
Old 05-17-2010, 09:48 PM   #2
SaleenFiend's Avatar
Re: P & P Question
Have you built the bottom end? What are you driving? I wouldn't run much more than 8-10 without worrying about the bottom end. 14lbs would be very extreme for a GT or V6 setup.
Old 05-17-2010, 10:02 PM   #3
Re: P & P Question
not yet. I'm fixing to tear into my motor tomorrow after work. 2001 Mustang V6. I'll be running 14lbs after I build it. Only during the tear down am I going to p and p the goods. So, about how much am I to expect in gain?
Old 05-18-2010, 05:15 AM   #4
Re: P & P Question
Porting and polishing your top end is nice, but don't forget about getting a forged bottom end. If you don't, the motor probably won't last 3 days at 14lbs.
http://www.supersixmotorsports.com/p...dInternals.pdf These are probably your best option for the build.
19Delta is offline   Reply With Quote
Old 05-18-2010, 10:15 AM   #5
Re: P & P Question
the power is in the cam, make SURE you get a nice custom grind for your given setup and lower that compression with forged internals then you should be good to go, get a forged crank if you can but if you stroke it to a 4.2 you may not can.
Ive heard Port/Polish doesnt do nearly as much on a forced induction setup~ but I could be WAY off, and I am sure a valve job will help as well.
Old 05-18-2010, 06:01 PM   #6
Re: P & P Question
Don't forget to get supporting mods such as fuel pumps & injectors
Old 05-18-2010, 08:19 PM   #7
Re: P & P Question
So heres what I already have. I'm running an SVT focus fuel pump, 39lb injectors, diablo mafia M.A.I. as far as supporting mods are concerned. Forged bottom is on its way. Gotta get the motor apart 1st, but once thats completed. I'm going to go with Ford Thunderbird SuperCoupe bottom end (forged-crank, conn. rods, and pistons).
I'd like to go with the bottom end that supersix has, I'm very familiar with supersix btw, but I simply do not have the funds for that, so SuperCoupe bottom end is going to have to do. I'd also like to do cam, but that = more $. And I already have a set amount already saved. So, what I have set back has to go a long way, cuz I have a LOT to get done, along with building the bottom end.
I work at a dealership here and both techs are recommending a 3 angle valve job once I get it apart.
Idk, I was just curious if you guys had any ideas of what I would expect once I do port and polish my heads, upper & lower intake. Are there any other tricks/mods that I could do that are free or low in cost when I have my motor apart?
Old 05-19-2010, 08:28 PM   #8
Re: P & P Question
i would say about 35-40rwhp with the port and polish. this is with a professional job and putting in larger valves, etc. i cant see the supercoupe being able to handle a whole lot more than 350 though, especially if the parts are worn. how much power are you looking for?
also, you should really look into a stroker kit instead.
tigerfan2771 is offline   Reply With Quote
Old 05-19-2010, 09:12 PM   #9
Send a message via AIM to VCS_SSSTANG
Re: P & P Question
Doing ported and polished heads and intakes is... pointless without swapping the cam.
VCS_SSSTANG is offline   Reply With Quote
Old 05-20-2010, 04:11 PM   #10
Re: P & P Question
true. i forgot all about that. i wouldnt say its worthless, but there is as much in the cams as there are in the heads and intakes
Old 05-20-2010, 06:14 PM   #11
Re: P & P Question
I would, thats a ton of work to do without the cam, plus our heads flow decently enough its the cam that's killing the combo.
Old 05-22-2010, 08:22 AM   #12
Re: P & P Question
*sigh*......so here's where I'm at at the moment. I have my motor out, disassymbled (down to block and bottom end), and am currently looking for a supercoupe bottom end. All I have been able to find/locate is/are the pistons and conn. rods. the cranks turning out to be unavailable (I've called everywhere). Which leaves me in a rock and a hard spot. Any suggestions?
B/c of this, would my stock crank handle the power I have planned? And on a diff. but related note, I've been trying to get a hold of tom at supersix with little success. Has anyone else had anymore success than I? Is he THAT busy? On vacation? Or going out of business?
Old 05-22-2010, 08:24 AM   #13
Re: P & P Question
So, would you say bypass the p & p idea and go with just a cam?
I'm shooting for about 400-420hp at the motor.
I'm considering stroking it, but, I can't get at hold of tom at supersix. He's the wonderful wizard of oz supposedly. The magician who bears all the knowledge.
Old 05-22-2010, 08:33 AM   #14
Re: P & P Question
As long as you have the money, id do both. Tom can be hard to reach at times. He is always travelling so it may take a while. However, we dont really have many options so just be patient.
Old 05-22-2010, 08:43 AM   #15
Re: P & P Question
well the p & p job I was gonna do myself, with the assistance of a technician I work with. Cool, I was beginning to think he was avoiding my calls, lol. So....what about my crank? Would it stand up to the extra power?
Old 05-22-2010, 09:22 AM   #16
Re: P & P Question
Probably not. Well it would, but not for a long period of time.
Old 05-22-2010, 09:54 AM   #17
Re: P & P Question
define long period of time.
Old 05-22-2010, 09:57 AM   #18
Re: P & P Question
It would depend on how hard you stayed into the throttle. You're wanting 400-420hp at the crank, so I'd say around 12ish psi? If you drove it cautiously it might last 6 months or a year, however, if you were hot rodding it, not so long. Also depends on the tune.
Old 05-22-2010, 10:30 AM   #19
Re: P & P Question
does anyone have any suggestions where I could get my hands on a good/new supercoupe crank for about $200-$250? Tuner houses? dealerships? etc? Like who? and whats their number?
Old 05-22-2010, 02:52 PM   #20
Re: P & P Question
Super Coupe Performance Parts - Ford Thunderbird, Mercury Cougar, Lincoln Mark VIII (8) and Ford Escape
Old 05-22-2010, 04:02 PM   #21
Re: P & P Question
I would think that the stock crank would hold up to 400 hp to the flywheel. however, if youre not being cautious, it is something that could break.
Another Amp Question Stumpy Mustang Audio & Video 8 06-11-2007 05:03 PM
Another Question on Amp/Subs jaredp Mustang Audio & Video 16 05-06-2007 02:33 AM
Wheel & tire question ricklmesa Pre-2005 V6 Mustang 5 10-01-2006 06:37 PM
amp to sub circuit question jimmy_beaner Mustang Audio & Video 29 05-11-2006 10:17 PM
&.5 Rear end question ponyboy1995 Pre-2005 V6 Mustang 2 01-26-2004 03:44 PM
02:53 PM
