Will this throttle body work? - Mustang Evolution
Old 10-07-2003, 08:38 AM   #1
Send a message via AIM to whipster24 Send a message via Yahoo to whipster24
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33558&item=2435679631
I'm wondering if this throttle body would work on my 97. I'm looking to upgrade to a larger flow path.
Or would it just be best to stick with the 56 mm TB?
Thanks
"This year will go down in history. For the first time, a civilized nation has full gun registration. Our streets will be safer, our police more efficient, and the world will follow our lead into the future!"
-Adolf Hitler, 1935
whipster24 is offline   Reply With Quote
Old 10-07-2003, 08:51 AM   #2
Danger Dude's Avatar
No it is way to big and it wont fit with out a adapter or machining your upper Intake crossover tube then if you do that you have have the throttle linkage off a 3.8 TB welded onto the 65mm T/B besides it is a waste your engine will only use the air it needs and will show no gains. I have stage 3 intakes and heads with a large cam and I am only using a 87-93 60mm Gt T/B
Old 10-07-2003, 10:32 AM   #3
Well, then I guess my question is what throttle bodies would work? I plan to port out my intakes once I have the TB
-Adolf Hitler, 1935
Old 10-07-2003, 10:37 AM   #4
well the BBK throttle body or contact RGR Robert Green and he can set you up with a stock P&P half shafted T/B or a modded BBK throttle body which he says is better than a 60mm or larger T/B
http://www.rpm-mustangs.com/rgrcfm/index.html
and here is his email rgrcfm1@yahoo.com
Old 10-07-2003, 11:31 AM   #5
RGR
Send a message via AIM to RGR
thanx for the plug Danger Dood
Yeah, I like the 56mm BBK, it looks nice and is a direct fit
for a 94-98 Mustang. Also, 1/2 shafted and ported it will
flow about like a 60mm 5.0 TB and there are no throttle
cable issues, TPS issues, or IAC issues. Plus the BBK
can be bored out to ~64mm later if you need that much,
but then your upper intake's crossover tube needs material
added to accomodate the porting required to use TB's that
big. The 56mm is a great piece!
I'd do an upper and TB for you, and I believe I can get
the TB for you, it would probably be $250.
rgrcfm1@yahoo.com Email me and
we can discuss it.
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Should i get a throttle body? blackonblack Pre-2005 V6 Mustang 21 12-07-2009 07:21 AM
throttle body ? wvstang5.0ho 1979-1995 Mustang GT 16 07-29-2008 10:48 AM
throttle body sonicpony Pre-2005 V6 Mustang 2 09-09-2007 12:23 AM
70 or 75 mm throttle body????? greg_g70 1996-2004 Mustang GT 9 12-20-2004 09:58 AM
throttle body Murph00 Pre-2005 V6 Mustang 5 11-26-2004 11:43 PM
10:08 AM
