Sound in 1st gear - Mustang Evolution
Old 10-07-2003, 01:04 PM   #1
Sound in 1st gear
Hi everyone,
driving a 2001 V6 auto. It runs great but as a pinging sound in first gear in the rpms before switching to second. It does not really bother, and has been like this for almost 2 years since I got it (used). I just want to know if this is a concern or a normal sound engine... I used to have a Ford Ka that had the same noise (look at http://www.ford-ka.net/ if you want to see that cutie, not sold in US. Great little car for approx. $7k in europe !!).
Thank you for bearing with car-dummy...
drichard is offline   Reply With Quote
Old 10-07-2003, 01:06 PM   #2
Danger Dude's Avatar
I have heard from alot of people that complain about that noise in 99+ V6 stangs.
Old 10-07-2003, 02:43 PM   #3
I'm glad to hear that. I'm not too picky about engine sounds, as long as performance is there and it does not mean any failure. I'd just like to know if someone has found where that comes from, and if it can be a problem. I find it interesting though that it does happen only in first gear. My old car used to have a similar sound in all gears at high RPMs, but that was after a trip at ~ 100mph for a car that is not suppose to attain that speed
Old 10-07-2003, 02:44 PM   #4
Rick0636's Avatar
If the noise is actually a ping or spark knock noise, no, its never normal, and its usually caused by carbon build up in an engine or too little octane in fuel. Cure? use higher octane fuel, blow out the carbon.
Old 10-07-2003, 02:46 PM   #5
actually some of the people were hearing the PVC valve fluttering
Old 10-07-2003, 02:57 PM   #6
If it is a spark knock noise, wouldn't I hear it in all gears ?
Old 10-07-2003, 03:00 PM   #7
yea you would. Is it loud are is it just a faint pinging? Next time you fill up use 93 or whatever you have at your location and see if that makes it stop.
Corey how can he tell if it is the PVC Valve fluttering?
Old 10-07-2003, 03:06 PM   #8
Pull the PVC out of the valve cover the vacume leak will make you car stumble and want to die. Just put your thumb over the end of the PVC and it should stop ticking if it does not keep looking
Old 10-07-2003, 03:15 PM   #9
It is rather faint and actually almost inaudible when the engine is cold.
I already tried switching to higher octane but it did not make any change.
Old 10-07-2003, 03:23 PM   #10
is it a pinging noise or clicking noise?
Old 10-07-2003, 03:32 PM   #11
It's always hard to described these sounds... I used to put a piece of cardboard on my bike frame, touching the weells when I was a kid... you know, to simulate an engine sound... It sound a bit like it. It's a rather high-pitched noise.
Old 10-07-2003, 07:34 PM   #12
well did you go out and do like I said only takes 5 minutes
Old 10-10-2003, 01:17 PM   #13
Thanks for your replies.
I appears to be a common sound for the 99+ V6. According to
Ford it comes from the exhaust valves...
Rebuilt AOD stalls engine in reverse and only has 1st gear 91StangGT5.0 1979-1995 Mustang GT 5 11-12-2009 04:02 PM
how (if it could) make my auto sound to a manual sound MaKaVeLi 1996-2004 Mustang GT 18 10-18-2006 09:56 AM
2006 V6 Manual Trans - Bucks in 1st Gear in AM lovcom Pre-2005 V6 Mustang 9 11-20-2005 09:08 AM
auto/manual tranny gear and rear gear STOCK ratios SpectorV Pre-2005 V6 Mustang 0 07-08-2004 02:41 PM
01:10 PM
