transmission fluid/filter change - Mustang Evolution
Old 05-20-2010, 07:14 AM   #1
I was going to do this myself, but not able to get the car far enough off ground to comfortably do the job, so I got an estimate from my garage that I do trust to do the work. My question is, they are quoting doing a complete power flush and fluid change.
I've been told different opinions by some that on a car as mine, 120,000 miles, they would only change out the pan fluid and filter, that after doing a complete they ran into problems.
Anyone have any first hand experience with either?
dd96stang is offline   Reply With Quote
Old 05-20-2010, 07:26 AM   #2
Re: transmission fluid/filter change
hmm if you have never changed your fluid and the car has 120k miles thats simply BAD in general, they say if you drain the fluid and put fresh in all the little metal flakes that have worn off over the years are what keeps the belts from slipping, those are gone with new fluid and can cause issues. I have no idea if thats true~
Old 05-20-2010, 09:08 PM   #3
I have always heard if you've never done it don't do it...
Personally I recommend a machine flush every 50k. Normally costs around $100 at a dealership to have it done.
Transmission Fluid Mustangfan2003 1996-2004 Mustang GT 5 04-28-2009 07:52 AM
Manual Transmission Fluid Change Gray Ghost 1979-1995 Mustang GT 0 04-11-2009 06:51 AM
Changing transmission fluid electricstang Pre-2005 V6 Mustang 4 12-16-2005 02:11 PM
Too much Transmission fluid? Ibanezplayer272 1979-1995 Mustang GT 2 11-27-2004 05:54 PM
Leaking Transmission Fluid?.. Ibanezplayer272 Pre-2005 V6 Mustang 20 09-07-2004 02:40 PM
09:40 PM
