Replacing the rear end - Mustang Evolution
Old 05-21-2010, 09:28 AM   #1
I'm going to be replacing the rear end in my 1995 Mustang. It has a 7.5 with ABS. I was needing to know if i was to buy a rear end without ABS if it would still bolt up and work. Or if i can take off the sensors from the old rear end. I'm looking to do this to save about $150.
Lukesta is offline   Reply With Quote
Old 05-21-2010, 10:58 AM   #2
Re: Replacing the rear end
you can take the axles out of your current rear end and reuse them in the new rear end~ as the gears I do believe are made into the axles (interchangable axles by the way) then reuse the other things, I think you can make it work~ You would need to inspect the mounting hard ware on the rear end, just take the wheel off and maybe the brake caliper and see if the sensor mounts universally or comes off so you can put it on the new rear end.
Old 05-21-2010, 05:47 PM   #3
^good info...you may want to look into a GT rearend...an upgrade from 7.5" to 8.8". Comes with the tlok in it and 8.8" gears and is much stronger as the spider gears in the 7.5" are weak.
Just a suggestion, as these days it costs about the same to swap in an 8.8" rear as it does to get a new 7.5".
Supercharging and replacing rear axle and gears for my mustang 2008 bmx_20055 Pre-2005 V6 Mustang 25 02-07-2009 10:06 AM
Rear End megax29 Pre-2005 V6 Mustang 8 08-27-2007 08:19 PM
Replacing Rear Tail light bulbs SN95 Pre-2005 V6 Mustang 5 02-18-2007 07:05 PM
99+ GT rear end jimmy_beaner Mustang Parts for Sale and Wanted 2 05-13-2005 02:33 PM
what is in my rear end. Black00GT Pre-2005 V6 Mustang 9 03-18-2004 04:33 PM
03:24 AM
