stang wont crank over at all - Mustang Evolution
Old 05-23-2010, 08:16 AM   #1
Hey just bought a 95 3.8 manual trans car for 100 dollars it had been hit in front drivers side. replaced the starter as it would not work, but still when i hit the key i have nothing. Everything else works it just wont turn over. Engine isnt locked up, and i checked all fuse and replaced the starter relay checked all the wiring. Also the fuel pump does not kick on i have reset the inertia switch, but still nothing. Help please. Thanks in advance
colemillion is offline   Reply With Quote
Old 05-24-2010, 02:03 AM   #2
MonteCitan's Avatar
Re: stang wont crank over at all
Fuel pump won't make much difference if the engine won't even crank over.. But that definitely needs to run for the car to run
How did the power wire look going to the starter?
Do you get a CLICK when you try to crank it? .. I know it's a stupid thought, but have you checked the battery?
Do you have fuel pressure at the schrader valve on the fuel line? I know I can barely hear my GT's fuel pump when I turn the key and it primes..
If you have fuel pressure..
Is the car in a spot where you can get a slight running start then put the car in gear and pop the clutch?
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 05-25-2010, 11:14 AM   #3
+1
First thing I was going to ask about was the battery, then fuel pressure...but usually if the battery works it'll still try to crank over, just won't actually start if it doesn't get fuel.
Have you checked the battery voltage? I would also suggest to check the Neutral Safety Switch.
UPRDanielle is offline   Reply With Quote
pistons rods and crank upton7 Mustang Parts for Sale and Wanted 0 02-18-2010 06:27 PM
4.2L Crank Gyro Pre-2005 V6 Mustang 1 05-22-2008 01:03 PM
cant get crank pulley off Thomas91169 1996-2004 Mustang GT 23 03-23-2006 09:25 PM
94-98 Underdrive Crank Pulley dapack69 Mustang Parts for Sale and Wanted 0 09-29-2005 10:09 PM
Crank Yankers Ken The Bar 5 05-12-2003 08:32 AM
05:01 AM
