which is good... - Mustang Evolution
Old 09-15-2006, 04:25 PM   #1
which is good...
Just want to know which of this is better..
rear end gears and performance chip or..
UDP, rear end and lightweight flywheel.
Im not sure about the UDP because I have a RF amp and two 10" subs.
might probably hav a problem with the alternator.
I have 2000 v6 stang with MAC shorty headers, H-pipe and dual exhaust. and k&n CAI..
( after installing rear end, does anyone knows what gonna be my top end?)
thanks guys...
donnie is offline   Reply With Quote
Old 09-15-2006, 04:27 PM   #2
bbunt302's Avatar
Re: which is good...
Gears and chip. Lightweight flywheels are nearly useless. The gears won't affect your top end. Your theoretical top end? Yes. Your actual top end? No. Aerodynamics and lack of power is more of a restriction on your top end than gears will ever be.
The UDPs will probably cause more problems than they are worth, unless you just get a crank pulley.
Scary stuff.
Old 09-15-2006, 04:34 PM   #3
Herbstang's Avatar
gears,SCT chip and 25% UDP bbunt302 right on the pullies just get the crank pully For gears 3:73 for 5 sp (But if I had to do it over I get the 4:10 ) ------------ 4:10 Auto
Old 09-15-2006, 06:02 PM   #4
so, there will be no problem if I just going to get the crank pulley? which is the best brand of pulley I should get? and is there a big diff between 3.73 and 4.10? i have 5 speed.
Old 09-15-2006, 07:15 PM   #5
00stang3.8's Avatar
Did the headers affect the sound of your stang?? I am trying to get the best sound possible out of mine and Im not sure what to go with to get there. Right now I have a single flowmaster and its ok, but Id like to get better if I could.
00stang3.8 is offline   Reply With Quote
Old 09-15-2006, 07:34 PM   #6
Zim
You want to **** me?
Zim's Avatar
get 4.10s, dont fear the gear.
I like toys
Old 09-20-2006, 03:24 PM   #7
would it be matter which brand should I go for rear end?
Old 09-20-2006, 03:26 PM   #8
go ford motorsports dont mess with richmond or motive.
Good to be here! Extreme New Member Introductions & Greetings 7 11-02-2009 02:22 PM
Good Good laugh Cajun JungleBoy The Bar 8 06-17-2008 04:01 PM
Good place, good prices? crazeflier07 Pre-2005 V6 Mustang 6 11-09-2006 07:48 PM
how good are you? Zim The Bar 7 10-27-2005 08:48 AM
This is the way im going if it'll be good. Matt'sredbeauty Pre-2005 V6 Mustang 4 10-17-2005 03:42 PM
08:16 AM
