Lagging throttle response/chugging at 2,000 rpms - Mustang Evolution
Old 05-24-2010, 09:41 PM   #1
Cool Lagging throttle response/chugging at 2,000 rpms
I recently bought a 2003 Roush stage1. I've hardly touched this thing yet besides the obvious fluid changes and some fuel system cleaner. To my knowledge the car has been sitting for a long time. It has 52,000 miles on it. I'm wondering if any1 has a clue to why this is happening. The gas mileage has been sh*t. I'm thinking about changing the spark plugs and getting a k&n cold air intake for now. Any suggestions or similar experiences with any help would be awesome
Jfckr is offline   Reply With Quote
Old 05-26-2010, 07:28 PM   #2
Ninethourpm's Avatar
Re: Lagging throttle response/chugging at 2,000 rpms
What fluids did you change? Did you replace the fuel filter? If you change plugs you might want to do the wires as well they could crack from age. Check to see if any vacume lines are cracked. Check for animal nest in the intake or dirty filter. Check your exhaust manifold for cracks (especialy passanger side)
2000 silver 3.8 5 speed,smoke tint,cold air intake,MAC Long tubes, MAC Catted H,MAC GT catback, SCT Livewire w/ Bamachips tune,
17x8Fr 17x9Rr Bullit Wheels More to come......
96 honda magna vf750, K&N, Vance and Hines pipes Rejetted carbs
Ninethourpm is offline   Reply With Quote
Old 05-30-2010, 08:09 AM   #3
Thanks for the tips! I changed the plugs yesterday finally. The car is already running WAY better. I'll buy those wires and change those as well, thank you for the ideas! MUCH APPRECIATED
Old 05-30-2010, 11:40 AM   #4
Tape's Avatar
clean your maf with q-tips and rub-alcohol
Tape is offline   Reply With Quote
Old 05-30-2010, 12:13 PM   #5
May want to run some sea foam through it as well. That will break up and remove any carbon deposits and grime making the engine run much better.
Old 05-30-2010, 10:37 PM   #6
Probably better off not useing the Q tips and just spraying it with MAF cleaner. You can easily break it with a q tip. Just spray the hell out of it with MAF cleaner untill its no longer black but silver.
I also second the seafoam. 2/3 in tank 1/3 thru the brake booster.
Old 05-31-2010, 06:12 AM   #7
Tape's Avatar
yeah, I guess you could break it but when I used MAF cleaner it left a film on the wires so I use q-tips and rub-alcohol for the past 8 yrs.
Old 05-31-2010, 11:09 AM   #8
Use another brand, MAF Cleaner should evaporate completly leaving no residue of its own.
Lagging page loads PureVenom ME Site Help & Announcements 12 07-23-2008 12:49 PM
Things are really chugging along. SrATEX Pictures and Videos 16 03-01-2007 04:37 PM
Throttle response 05STANG Pre-2005 V6 Mustang 6 10-29-2006 08:30 AM
Iran Response to US Attack Would Be Two Fold Brent The Bar 24 04-28-2006 05:36 PM
HEY! DE, over here! Response to 3.8 post Morpheus The Bar 1 08-04-2003 11:06 AM
05:16 PM
