1996 Mustang P1443 Evaporative Emissions (EVAP) Canister Purge (CP) Valve - Mustang Evolution
Old 09-17-2006, 07:22 PM   #1
Can anyone tell me where the Evaporative Emissions (EVAP) Canister Purge (CP) Valve is on my 1996 Mustang. I am getting an error code, P1443 checked online and that is what she told me.
Old 09-17-2006, 07:54 PM   #2
MonteCitan's Avatar
Re: 1996 Mustang P1443 Evaporative Emissions (EVAP) Canister Purge (CP) Valve
let me know what the initial results are
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 09-17-2006, 09:05 PM   #3
The software SCT supplies to datalog is buggy
SCT Flash - So I am trying to use XC2LiveLink...
I can't seem to get this to work
Old 09-17-2006, 09:45 PM   #4
Which firmware do you have on your tuner? That is where the initial problem with data logging comes from. Then there was an iffy version of the live link on top of that. I had the same problem and can no log no problem since i updated my live link to the current as well as my tuner to the latest firmware.
Old 09-17-2006, 09:47 PM   #5
SCT Live Link: Version: 3.1.31
Firmware: Version: 1.14
Old 09-18-2006, 05:01 AM   #6
I use that version every day to tune cars, it does have its quirks but I don't have a problem most of the time (and I have to rely on it, otherwise I can't tune cars properly). I primarily use on PC logging though, not on device.
The canister is in the drivers side front fenderwell, and I think all the valves are back next to or above the tank.
Justin Starkey
2007 Shelby GT500 705RWHP/708RWTQ
2000 Mustang 3.8 A4 TT 450RWHP/475RWTQ 10.996@127 17psi stock 3.8
2006 F250 CC 4x4 6.0L 14.3 @ 93
2006 Mustang 4.0 M5 Vortech 13psi 395RWHP/374RWTQ wife's car
justin00stang is offline   Reply With Quote
Old 09-18-2006, 02:38 PM   #7
DarkShadow's Avatar
Send a message via AIM to DarkShadow
Those are the versions I used also. It does have a few problems but otherwise I didn't have too much trouble.
DarkShadow is offline   Reply With Quote
Old 09-18-2006, 03:13 PM   #8
Of course it all screws up when I try to use it
Old 09-18-2006, 05:16 PM   #9
After a little researching I came across this:
DTC P1443 indicates a mechanical fault in the Evaporative Emission (EVAP) Purge Flow System. Nine times out of ten this code is due to a loose gas cap. So that would be the first thing to check.
The other things you can look for are pinched, plugged, blocked, cracked, cut or disconnected vapor hoses between the fuel tank and carbon canister. Check for a cracked or broken carbon canister or fitting(s).
Other than that, you will need a scan tool to check the EVAP valves, sensors and electrical wiring.
Ford Escort DTC P1443
Hrm
Old 09-18-2006, 09:31 PM   #10
DarkShadow's Avatar
Normally the code for the gas cap is like P0404 or soemthing like that, and it never says anything about the cannister at all. I guess it could still be a bad cap possibly letting evaporated gas fumes through, but I doubt that with that particular code...
Old 09-18-2006, 09:33 PM   #11
Yea I doubt it as well. Wish I could get this damn SCT software to work
Old 09-25-2006, 01:24 PM   #12
Any trick to changing out the EVAP Canister?
Old 09-25-2006, 04:09 PM   #13
MonteCitan's Avatar
Getting pissed and a BFH always worked for me.
Old 09-25-2006, 04:11 PM   #14
That much trouble?
Old 09-25-2006, 06:10 PM   #15
MonteCitan's Avatar
I honestly don't know.. if I could picture where it was on your car I could offer you more help.. but getting the canister vent off can be a PITA if you live in a corrosive area.. (near salt water?)
Old 09-25-2006, 06:22 PM   #16
Old 09-25-2006, 06:56 PM   #17
MonteCitan's Avatar
I saw his post but that doesn't help me visualize it, I know I've seen one on a 3.8 mustang but I cant picture it.. sorry
Old 10-16-2006, 12:28 AM   #18
I need to know what it is I need to buy to fix this. If it is the Evaporative Emissions (EVAP) Canister Purge (CP) Valve how much will it cost to replace it (just buying whatever I need to do the job) and what exactly is involved with replacing it?
Old 10-17-2006, 12:01 PM   #19
Herbstang's Avatar
This might give you a idea of whats involved http://www.autozone.com/servlet/UiBr...3d801dd5d9.jsp
Old 10-17-2006, 12:12 PM   #20
Thanks a bunch man that helps a ton
Old 10-17-2006, 12:51 PM   #21
Alright I narrowed it down to the control valve being the problem.
Anyone care to take a picture of where this is on a 96 V6? All the info seems to lead me to 5.0 pictures and the Haynes manual only shows the 4.6
Old 10-17-2006, 05:03 PM   #22
Herbstang's Avatar
Cool !! Can't find anything for a V-6 Closest I came across was a Ranger with the same problem as you Check Engine Light on 96 Ranger 4 Cylinder - Ford Forums - Mustang Forum, Ford Trucks and Cars Probally won't help
Old 10-17-2006, 05:14 PM   #23
Yea I came across that as well.
Old 10-18-2006, 06:13 AM   #24
Herbstang's Avatar
Damn !! Sorry I failed you Oh Mighty one :worship:
Old 10-18-2006, 02:39 PM   #25
My car failed me.
I hate it lol
Old 02-01-2007, 03:40 PM   #26
Bump. Anyone able to help me out here? How do I replace the control valve on a V6 Mustang?
Old 02-02-2007, 10:22 PM   #27
bbunt302's Avatar
Consider you live in Alabama...
And it's an Evaporative Emissions Canister Purge Valve...
You rip it out and throw it in the nearest trash can.
Scary stuff.
Old 02-02-2007, 10:53 PM   #28
Ibanezplayer272's Avatar
Send a message via AIM to Ibanezplayer272 Send a message via MSN to Ibanezplayer272
:yup:
2007 Windveil Blue Mustang GT
Mods : Intake, Stubby antenna
Rolls are for fat chicks
Ibanezplayer272 is offline   Reply With Quote
Old 02-02-2007, 11:25 PM   #29
Man I would if I knew where the hell the thing is and what all is involved in removing it so my car runs right.
Old 08-08-2008, 06:44 PM   #30
I'm assuming you've found it since it's been awhile, but I actually know the answer to this one and I figured I'd post an answer for future questioners.
I just pulled off a random part (cracked lines needing replacing) and discovered that this lovely part (9C915) is in front of/under the AC dryer (big, black canister attached to the wall) next to the firewall on the passenger side. It was almost in my way when I was taking off the dryer support clamp. It's got a tube coming in the top on one side towards the wheel and another tube heading the other way...and an electrical connector on the bottom. It's just a cylinder with a black rubber sleeve around it, about 2.5 inches long and 1.5 across.
One of the hoses leads to a black box that the pictures call the "EVAP canister" that is under the passenger front fender near the door hinge. If you take off the fender bolts (1 behind the turn signal and 3 on the top) you can pry the fender back enough to get your hand in there to the canister...though you might bend the 2 bolt mounts that are behind the door hinges...or you could take the whole fender off, but those last two bolts are a serious pain to get off (at least I've found them to be so.)
shustwit is offline   Reply With Quote
Old 08-11-2008, 05:35 PM   #31
Scut95's Avatar
wow that sucks....typical Ford making it harder than it has to be
Old 09-29-2008, 06:28 PM   #32
Got the same problem-what was the outcome? My research also shows a purge flow sensor could fail.
sanfran is offline   Reply With Quote
Old 01-30-2011, 05:59 PM   #33
I have a 1996 3.8 mustang and throwing codes p1443 and missing/hestitating on acceleration. It seems there are a lot of parts to go into this evap emissions code. Guessing that I am a female I do not really know what parts could be involved trying to find the definite problem with this code. The lady at Advanced auto parts said the only place that sold parts for this code was the dealer. If I could figure out what part was bad and just buy the part that would be better so I could do it myself
laurencreamer is offline   Reply With Quote
Old 01-30-2011, 08:32 PM   #34
MC770's Avatar
Old thread, post a thread in the v6 section
~2003 Zinc Yellow Terminator Cobra~
~482 RWHP / 487 LBS Torque~
MC770 is offline   Reply With Quote
1996 mustang
2004 GT EVAP Questions SSgt Dan 1996-2004 Mustang GT 16 09-25-2009 01:20 PM
CODE PULLED P1443? BILLFORD01 1996-2004 Mustang GT 13 08-06-2009 11:20 AM
Evap leak Small jmarcinko00gt 1996-2004 Mustang GT 6 09-03-2008 10:26 AM
Bypass valve & Blowoff valve sporter 2005-2010 Mustang GT 7 05-27-2007 02:57 PM
Code P1443 How to fix it? Neptuno Pre-2005 V6 Mustang 2 09-03-2004 08:28 PM
02:35 AM
