When I shift... - Mustang Evolution
Old 09-25-2006, 02:25 PM   #1
When I shift...
or at least attempt to, sometimes (more and more all the time) it is very hard to get the car into first, and sometimes I even struggle getting it into gear on the road. The shifter feels "sticky" when taking it out of gear and almost always grinds when I put it into reverse. I have about 25% wear on the clutch and I was told to get a new one by the mechanic. Could a new clutch possibly alleviate these issues? Maybe a smaller lighter one as long as I have to?? And as long as I need to get a new clutch, how worth my wile would it be to get an aluminum flywheel to replace the stock one?
HotRod.riguez is offline   Reply With Quote
Old 09-25-2006, 02:41 PM   #2
Re: When I shift...
sounds like the clutch cable is not pulling the clutch out enough (into neutral) or the clutch is nearly toast.
If your petal is VERY close to the floor before you feel tension or just always then chances are your not pulling enough of the cluch cable with the clutch petal so its not in neutral fully. You can fix this with different thing~ might want to start wtih a new clutch cable (unless this one is not high milage) and then a new quadrent/firewall adjuster to ensure you are engaging fully.
Old 09-26-2006, 02:06 PM   #3
rydog's Avatar
Send a message via MSN to rydog
Re: When I shift...
Originally Posted by HotRod.riguez View Post
it is very hard to get the car into first, The shifter feels "sticky" when taking it out of gear and almost always grinds when I put it into reverse.
your syncros could be going bad and that's why it is hard to put it in 1st and reverse they use the same syncros I do believe(someone correct me if I am wrong). If the clutch adjustment doesnt work it might be time for a rebuild . How many miles does it have on it?
97 V6-GT40 turbo-42#rs-BA2800 MAF-4.10's & tlok-254rwhp-369rwtq
Turbo'd by-TMA Turbo(http://www.tmaturbo.com/)
Tuned by-Dyno Tuned Performance(http://www.dtpracing.com/)
rydog is offline   Reply With Quote
Old 09-26-2006, 02:36 PM   #4
Zim
You want to **** me?
Zim's Avatar
Re: When I shift...
I agree, it sounds like you just need to adjust the clutch cable. Try pulling up on your clutch pedal and seeing if it will self adjust anymore. If not, get a Firewall adjuster, and aftermarket clutch quadrant as well as an adjustable cable... With all that stuff, you should be good to go. Look for UPR kit, they're affordable and are a quality piece. If you dont want to go aftermarket and prefer ford to fix it, just tell them to check your clutch quadrant and cable because you think it may be warped or stretched.
I like toys
Old 09-26-2006, 02:57 PM   #5
MonteCitan's Avatar
Re: When I shift...
what trans? t5s/45s I've always had to go into 5th then reverse to keep it from grinding..
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 09-28-2006, 11:05 PM   #6
Re: When I shift...
I already had the engine rebuilt this past summer, and I dont know what the trans is. Its a pretty stock 3.8L V6. Putting it into 5th gear really helped a lot, but why do I have to do this? Why cant I just put it into reverse without all the noise.
What about the clutch and flywheel as I had asked about before?
Old 09-28-2006, 11:37 PM   #7
MonteCitan's Avatar
Re: When I shift...
reverse is not synchronized like the other gears are..
Which Shift Handle PureVenom Mustang Audio & Video 42 11-20-2006 07:56 AM
Shift Kit? SKELETON08 Pre-2005 V6 Mustang 6 06-20-2005 06:29 PM
shift kit jimmy_beaner Pre-2005 V6 Mustang 24 08-26-2004 02:45 PM
99+ shift kits thirstymate Pre-2005 V6 Mustang 2 08-25-2004 11:32 AM
shift light? chipshot101 Pre-2005 V6 Mustang 16 08-19-2004 01:15 PM
03:31 PM
