Car would not start-could not be jumped-then started - Mustang Evolution
Old 05-31-2010, 08:17 PM   #1
richardcrowson1's Avatar
Today,
My car would not start, I tried jumping with my wife's car. Then, I called a towing company. They could not jump it off. I was getting ready to have it towed, and turned the key on to see if the auto trans would shift into neutral for the tow truck and the car started. I cleaned the battery terminals, made sure they were tight.
The clock was off for over two hours. No sounds came from the normal buzzers, the radio would not work.
Both the speedometer and Tach pegged and stuck at the top of the meters, (wierd).
Outside of an invasion from a UFO, (on TV), I have never seen anything like this. It just wouldn't work, then it did.
I did have the trunk open while I was loading some things into the trunk. The trunk light may have been on for twenty minutes. The car door was open about that long also. I can't imagine that this drained the battery.
I stopped at the local AutoZone and had the battery checked. It is perfect.
I bought two new battery terminals and cleaned the battery and posts.
I broke the fuse holder by trying to take the positive lead off while doing this, but, otherwise everything is back in working order.
I checked the fuel pump switch, even though I don't think it could cause this.
Any ideas about what happened and how I can prevent it from happening again?
richardcrowson1 is offline   Reply With Quote
Old 06-01-2010, 01:07 AM   #2
MonteCitan's Avatar
Re: Car would not start-could not be jumped-then started
Fuel pump wouldn't cause a no crank condition..
When you put the key to the on position, did you get the usual Christmas tree, with all lights on or was the dash dark?
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 06-01-2010, 07:19 AM   #3
jimmy_beaner's Avatar
Region: Iowa
The shop I had my starter replaced at said sometimes a starter can develop a dead spot. I guess if it was at a bad spot, it might not start but that doesn't get to why your stuff would be pegged. Any CEL?
Old 06-01-2010, 06:41 PM   #4
Hi,
Actually there were not lights or sounds. There must have been some voltage or the gauges would not have pegged and stayed in position . However, not enough for the buzzer to ring when opening the door with the key in the ignition.
Old 06-02-2010, 12:53 AM   #5
MonteCitan's Avatar
That is definitely strange, sounds like it could be a ground-point issue, or possibly a short in the ignition wiring?
The gauges being pegged could be a self-test that instrument cluster does, I've seen many Fords do this when battery is disconnected/reconnected then key is turned on... But they don't stay pegged and the car definitely starts afterward, however if there's a bad ground.. It could be tripping a self test frequently?
And when the car actually started, the path was complete again.. Has the car continued to act up or is all well now?
I'm baffled!
Old 06-02-2010, 06:40 AM   #6
You might be on something. I pulled off the battery terminals and replaced the positive with a "gold plated" top of the line connector. The negative pole terminal I purchased designed for negative poles would not fit. I cleaned up the old terminal and replaced it. It was badly coated with oxidation. Because it was lead, it was easy to shine it up. I bought a battery pole shim and will put the more expensive terminal on this weekend. Maybe the attempts at jumping the car moved the negative terminal just enough to cause it to arc through the oxidation. I think you have something in this.
The only down side is that I needed more slack cable from the fuse block and tried taking off the bolt holding the positive cable.
Old 06-02-2010, 07:18 AM   #7
Region: Iowa
You may be able to use aluminum foil as a temporary spacer. A problem I had with my v6 is that the negative terminal wasn't tight around the post and it arced. This oxidized the surface and it conducted like **** and the car went dead. If your negative is loose on the post, you should certainly fix this first.
Old 06-02-2010, 08:20 PM   #8
Thanks,
Rick
Old 06-02-2010, 08:25 PM   #9
Region: Iowa
Originally Posted by richardcrowson1 View Post
Thanks,
Rick
did it work?
Car won't start? Dude87 1996-2004 Mustang GT 16 10-13-2008 11:32 AM
Car Won't Start joseandmarilyn 1979-1995 Mustang GT 11 02-18-2008 12:22 PM
Car won't start V6STANG007 Pre-2005 V6 Mustang 31 12-07-2004 06:07 PM
04:55 AM
