Gears - Mustang Evolution
Old 10-03-2006, 03:43 PM   #1
megax29's Avatar
Send a message via AIM to megax29 Send a message via Yahoo to megax29
Gears
Gears is the next thing on my list. What will my rpms be at when cruising at 70mph w/ 4.10s and 3.73s? I cruise at 2100 now with the original gears and at about 3100 when I hit the overdrive. Also if I drop in my gears w/o having a tune how will affect the cars performance?
V6 Midnight Black
CAI w/ K&N Filter, Tokico Complete Suspension kit, Single Flowmaster w/ turndown, GT rear sway bar.
megax29 is offline   Reply With Quote
Old 10-03-2006, 03:55 PM   #2
Re: Gears
you wont need a tune for rear end gears it wont effect it. The only thing you will need is a way to calibrate the speedo. You should be able to run a chip or a speedcal unit (depending on year/tranny)
For an auto (since the gearing is worse than a manual) 4.10s are generally a good choice but you really need to do a tlok since its the same amount of work.
I cant remember the exact percentage that the rpms will go up but if memory serves me right from stock to 3.73 it will be about 250-300 rpms more than what it currently is at~
Old 10-03-2006, 04:13 PM   #3
Re: Gears
:pop2: Look here.
Tech Equations - ThirdGen.org
http://www.mustangevolution.com/foru...ula-22451.html
JROC is offline   Reply With Quote
Old 10-04-2006, 04:24 PM   #4
KyleUSAF's Avatar
Send a message via AIM to KyleUSAF Send a message via MSN to KyleUSAF
Re: Gears
you might want to get a tune too while you're at it..instead of getting a speedcal, then a tune if you plan on taking it that far
Originally Posted by Darkshadow
I could say nothing for my complete awe. He then. confidantly, purchased the gallon.
KyleUSAF is offline   Reply With Quote
Old 10-04-2006, 11:24 PM   #5
megax29's Avatar
Re: Gears
JROC: This info seems very helpful if I were able to determine all the numbers to plug into the formula. My car is an 04 3.9L automatic and my tires are stock 225/55/16. I need to know rear end ratio, transmission gear ratio and tires' radius in inches. I don't know what type of transmission I got. I've taken it to a few shops to ask about gears and some say its got an AOD and other a 4rw70 or something like that, what transmission do I have?
V6 Midnight Black
Old 10-04-2006, 11:26 PM   #6
megax29's Avatar
Re: Gears
If 3.73s give you rpms of 2400 when cruising at 70mph that's perfect for my liking. How about 4.10s?
V6 Midnight Black
Old 10-05-2006, 08:09 PM   #7
megax29's Avatar
Re: Gears
Any input anyone? Doesn't n e one have 4.10s?
V6 Midnight Black
Old 10-09-2006, 10:59 PM   #8
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
Re: Gears
you have a 4r70w transmission with an overdrive hence the AOD.
with 4:10 you'll be around 2750 or so at 70 MPH.
try this RPM calculator....Gear Comparison
It's a bit easier to input your tire size info.
99 Cobra: flowmasters, 18x9.5 cobra R's, soon to be tuned and geared. daily driver
99 V6:in avatar, Mac Cai, true duals/flowmaster 40's ,UDP, custom tuned, bullitt suspension 18" wheels...taken by mother nature
I_luv_HP&trq is offline   Reply With Quote
Old 10-18-2006, 03:06 PM   #9
megax29's Avatar
Re: Gears
Hey man thanks that calculator was really helpful. I think 4.10s maybe to much for me since I do a lot of hwy and 3.73s may not be enough so I'm thinking of going with 3.90s. Do you know of any shops that can do this job at a reasonable price in the bay area? I've asked at 3 shops and all 3 of them have quoted over $600 out the door.
V6 Midnight Black
Old 10-18-2006, 03:14 PM   #10
Zim
You want to **** me?
Zim's Avatar
Re: Gears
I can tell you I roll at 2800RPMs at 80mph with 4.10s. My old are with an auto and the same gears cruised at the same RPM as well. 70 youll probably be around 2500-2600 RPMs with 4.10s, I dunno about 3.73s
I like toys
Old 10-18-2006, 04:31 PM   #11
bbunt302's Avatar
Re: Gears
With 3.73s, I do 80 at about 2600 RPMs.
Scary stuff.
Old 10-24-2006, 02:32 PM   #12
megax29's Avatar
Re: Gears
I do about 2450 rpms at 80mph with my stock gears. I think they're 3.27
V6 Midnight Black
NEED HELP WITH GEARS!! Motive 4.10 gears? Cant find ford racing? Camaro Eater Pre-2005 V6 Mustang 4 06-23-2010 10:57 AM
3.73 gears tim11 Pre-2005 V6 Mustang 5 10-25-2005 08:21 AM
4.10 gears powerhungry966 Pre-2005 V6 Mustang 7 10-23-2005 06:53 PM
gears 8.8 or 7.5 strike1980 Pre-2005 V6 Mustang 5 07-31-2005 11:05 PM
Factory Gears Vs. Racing Gears tire Pre-2005 V6 Mustang 0 07-21-2003 04:02 AM
10:26 AM
