clutch is noisy - Mustang Evolution
Old 06-05-2010, 06:40 AM   #1
clutch is noisy
98 3.8 v6 mustang, when I push in the clutch I hear loud squealing noise. When clutch is engaged there seems to be no slippage and no noise. Please help
garyactech is offline   Reply With Quote
Old 06-05-2010, 11:22 AM   #2
MonteCitan's Avatar
Re: clutch is noisy
I want to say it's likely your pilot bearing (the bearing in your crankshaft, that the nose of your input shaft rides in) when the clutch pedal is depressed, the bearing spins around the nose while the nose stays stationary..
in other applications, like clutch out, vehicle in neutral - or vehicle in gear, the input shaft and crankshaft spin at the same speed
Throwout bearing you'd mostly hear when pushing in the clutch pedal/ releasing the clutch pedal any time the engine is spinning, that tends to be more of a ratchety/grinding sound, though..
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 06-07-2010, 07:29 AM   #3
Re: clutch is noisy
if you take the transmission out to fix this replace it all (its cheap parts anyway)
resurface (inspect to make sure you can) flywheel (if not replace)
pilot bearing
throwout bearing
inspect fork arm/pivot ball stud for wear replace as needed
pressure plate/clutch disk
check tolerance on input shaft play adjust as needed
basically a full clutch job with bearings and inspection of the parts
finish off with fresh trans fluid and you should be good to go.
its pretty easy to get the transmission out of your car as it can be removed from the bellhousing via 4 bolts.
clutch juced302 1979-1995 Mustang GT 4 04-09-2009 08:48 PM
clutch help mtchll50 1979-1995 Mustang GT 9 09-10-2006 07:09 AM
New clutch electricstang Pre-2005 V6 Mustang 2 05-22-2006 03:04 PM
AC Clutch Checkmate Pre-2005 V6 Mustang 6 12-25-2005 12:31 AM
noisy clutch! red pony V6 Pre-2005 V6 Mustang 11 04-27-2005 03:49 PM
03:18 AM
