02 sensor? 1998 v6 - Mustang Evolution
Old 06-06-2010, 06:02 AM   #1
Question 02 sensor? 1998 v6
i have a code of 1151 which tells me it's for lack of upstream heated oxygen sensor switch, sensor indicates lean , bank no.2 my questions are is the sensor bad and should i replace it and which one is bank no.2
coolmustanguy is offline   Reply With Quote
Old 06-06-2010, 06:03 AM   #2
re: 02 sensor? 1998 v6
thanks for your help
Old 06-06-2010, 10:31 AM   #3
OsirisGuy's Avatar
Bank 1 refers to the side of the engine where cylinder 1 is located. I believe this is on the passenger side for your car. I do not have my Haynes manual or service manual to confirm so double check.
For additional info about what this code means, visit:
OBD Trouble Code: P1151 Lack of HO2S-21 Switch, Sensor Indicates Lean
Simply put, they explain it a lot better than I can. They give you probable causes, what to look for, and what to check for.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 06-07-2010, 11:56 AM   #4
Tape's Avatar
Re: 02 sensor? 1998 v6
swap #2 with #1 and if you get an error for bank 1 then you know its the O2 sensor.
Tape is offline   Reply With Quote
Old 06-22-2010, 06:01 PM   #5
O2 SENSOR redGT773 2005-2010 Mustang GT 21 01-29-2009 01:17 PM
M.A.F. Sensor 03GTNEWB 1996-2004 Mustang GT 5 07-15-2008 11:45 AM
o2 sensor Mustang414 Pre-2005 V6 Mustang 0 05-18-2005 08:36 PM
O2 Sensor Out. Dom Pre-2005 V6 Mustang 18 12-18-2004 07:58 PM
09:21 PM
