Need quick help! Need to find 4.10 gears for 2010 v6 mustang?? - Mustang Evolution
Old 06-07-2010, 08:23 AM   #1
Hey everyone,
I need to find 4.10 gears for my 2010 v6 mustang, I. Thought american muscle would have them but they DO NOT. Any help or links would be wonderful! Thanks everyone!
Camaro Eater is offline   Reply With Quote
Old 06-07-2010, 11:41 PM   #2
OsirisGuy's Avatar
Re: Need quick help! Need to find 4.10 gears for 2010 v6 mustang??
79-10 Mustang Yukon 7.5" 4.11 Rear End Gears at LRS - Same Day Shipping!
If I could make a suggestion, and that is to upgrade your rear axle to a 8.8". I'm pretty sure that an axle from an 2005+ will bolt right in. At least that's what I'm seeing. I don't know off the top of my head if anything was changed, e.g., gear ratio wise, that would make 05-09 rear end gears incompatible with 2010.
I would also check with Ford Racing for a FRPP or have you called American Muscle to check with any cross compatibility.
Also, I was doing some browsing and found FRPP gears, #M-4209-L410N. These were discountinued from Ford (I'm guessing this is when they handed over production to Motive performance). If gears from other years fit 2010 then I would try to find these since you can probably get a good deal on them.
BTW, one set of gears should be compatible for the last 2 or 3 decades, i.e., 8.8" gears will work from 1979 - 2010 (so says American Muscle), and 7.5" will work from 1979 - 2009.
But I'm really only good with 01-04 Mustangs and not as familiar with the S197 so I'm sure someone will chime in and correct any information I missed.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 06-08-2010, 05:31 AM   #3
Awesome with the info. I really appreciate the help, thank you so much! I actualy have called ford and motive to see what's what. As you mentioned ford only makes the 8.8 gears, they took over making the gear upgrades in the last year due to complaints about thr noice/whine of motive gears, howeber ford still allows motive to make the 7.5 exclusivly for them. I have searched for the old ford racing 410's with no sucess, furthermore what I have heard is that the pinion on the 2010 mustangs is slightly angled so I have to be very careful when trying to find gears that claim to fit. Motive says there's will, we shall see. I may just convert to the 8.8 rear end, if the price is right! Anyways, thank you so much for all your help and insight, I really appreciate it!
v6 mustang
NEED HELP WITH GEARS!! Motive 4.10 gears? Cant find ford racing? Camaro Eater Pre-2005 V6 Mustang 4 06-23-2010 10:57 AM
New owner of a 2010 GT 373 rear gears jrny99 New Member Introductions & Greetings 9 10-19-2009 05:30 PM
2010 Mustang GT vs 2010 Camaro SS OsirisGuy Pictures and Videos 39 09-01-2009 12:56 PM
08:28 PM
