Highway RPMs after Rear Gear Swap - Mustang Evolution
Old 06-07-2010, 11:33 AM   #1
I'm thinking about changing the gearing in my '95 V6er to either the 3.73 or the 4.10 7.5" to get a little more low end. My only concern is will it kill the ride at highway speeds? Currently when cruising down the highway in OD I'm at about 1200RPMs @ 55MPH, 1500 @ 65MPH and 1800 @ 75MPH. What can I expect at highway speeds with either the 3.73s or the 4.10s?
Thanks!
charrier90 is offline   Reply With Quote
Old 06-07-2010, 11:42 AM   #2
re: Highway RPMs after Rear Gear Swap
I think 2.73 vs 3.73 is 25% more gear~ so expect 25% higher rpms (1800 at 75 will be around 2250)
Old 06-07-2010, 05:33 PM   #3
Found a great calculator at Gear Ratio Calc.
From the looks of it, going to the 4.10s would produce RPMs pretty close to what you would see with the 2.73s with OD turned off. Should still be fairly highway friendly. Time to stop thinking about it and just do it!
94 V6 Gear Swap?? (5spd Car) jimmyjams Pre-2005 V6 Mustang 1 04-23-2008 10:34 PM
Rear Gear Ratio natestang22 Pre-2005 V6 Mustang 2 07-20-2007 11:31 AM
Gear and axle swap questions. DarkShadow Pre-2005 V6 Mustang 15 09-07-2005 02:18 AM
auto/manual tranny gear and rear gear STOCK ratios SpectorV Pre-2005 V6 Mustang 0 07-08-2004 02:41 PM
rear gear and t-lok STEVE Pre-2005 V6 Mustang 40 05-28-2004 06:30 PM
01:27 PM
