car bogs at like 2k rpm :( - Mustang Evolution
Old 10-09-2003, 02:12 PM   #1
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
Dont know whats up. Car runs fine then *sometimes* at around 2k rpm's the car will bog and not accelerate.
When the car starts bogging if i slam on the gas it will start to go, and it will eventually stop bogging like it is and start to accelerate.
ANyone have this problem or know whats up?
Rellik is offline   Reply With Quote
Old 10-09-2003, 02:44 PM   #2
I'm going to guess fuel injectors? Fuel Pump?
Seems like when you give it alot of gas it stops so maybe the injectors are clogged?
Old 10-09-2003, 02:48 PM   #3
my guess is fuel pump. My car was running lean a while ago. Maybe its time to get a new one.
Ill add one in my wtb add. But anyone have any other ideas?
Old 10-09-2003, 05:08 PM   #4
tire's Avatar
Send a message via AIM to tire
it could be fuel pump or injectors... the WOT bogging seems like something indicative of that. how old is the car or since you have changed your fuel pump?
tire is offline   Reply With Quote
Old 10-09-2003, 05:54 PM   #5
I never changed my fuel pump.
Old 10-09-2003, 05:56 PM   #6
yea I am guessing thats going to be it then. I need to change mine to.
So write a how to
Old 10-09-2003, 06:27 PM   #7
I have one from another mustang gas tank, ill use that as a temp fix.
till i get my 255lph one.
Old 10-09-2003, 06:36 PM   #8
Danger Dude's Avatar
It could be a intermittent TPS
Old 10-10-2003, 09:21 AM   #9
iam changing my fuel pump saturday after work. Ill let everyone know how it come sout.
Old 11-02-2003, 01:33 PM   #10
PuReHeLL's Avatar
Send a message via AIM to PuReHeLL
My car did the same bog for a little while. Turned out to be all i needed was some fuel injector, and an oil change. Runs fine now... 8)
OuT --> PuReHeLL
http://www.mustangevolution.com/foru...ine=1107000257
PuReHeLL is offline   Reply With Quote
Old 11-02-2003, 04:28 PM   #11
My fuel pump died.
Old 05-20-2004, 05:58 PM   #12
Send a message via AIM to Stang_On_17s
Happend to me also....
This happend to me also and it ended up being the part on the top of your throttle body (i for got what it was called) but i know there cheap and it fixed my problem
Stang_On_17s is offline   Reply With Quote
95 v6 mustang bogs down when it gets warmed up stevens005 Pre-2005 V6 Mustang 5 03-10-2009 08:08 PM
take off RPM NotoriousSPG Pre-2005 V6 Mustang 3 08-12-2006 07:48 AM
RPM drop Murph00 Pre-2005 V6 Mustang 12 07-16-2005 12:32 PM
whats the better rpm curve?/whats a good car choice? Thomas91169 The Bar 7 12-05-2003 10:24 PM
04:38 PM
