How to Flush the Clutch Fluid on an 07 - Mustang Evolution
Old 06-08-2010, 10:46 AM   #1
I have a 2007 V6 5-speed. It's really hard to shift when it gets warm and also sometimes acts like the clutch doesn't disengage completely. Normally that happens when the Hydraulic fluid is contaminated. Does anyone know how to flush the system without dropping the transmission? There is no bleeder valve on the system.
Mom's - 2007 V6, 5 Speed, Dual Exhaust, CAI, 8.8 with 3.73 gears, Stage 2 Clutch
1965 351C Dragcar Restoration in progress,
1966 289 Pony Restoration in progress
Son's - 2003 V6 4.3L Stroker with lots of goodies,
1965 Dragcar in progress,
1965 Restomod in progress
mxw1090 is offline   Reply With Quote
Old 06-08-2010, 07:03 PM   #2
Tape's Avatar
Re: How to Flush the Clutch Fluid on an 07
its cable controlled not fluid, you guys do have a tr3650 correct? you may just need to change the trans fluid. It takes auto trans fluid.
Tape is offline   Reply With Quote
Old 06-08-2010, 07:11 PM   #3
Tape's Avatar
you will see a plug on the bottom of the transmission that has a square in the center of the plug, it's a drain plug, you get a ratchet without a socket and push it into the plug then just remove it.
Old 06-09-2010, 12:03 PM   #4
I need to flush the hydraulic fluid in the clutch not the transmission. Th 07 V6 has the Tremec T5, probably the worst trans ever put in a mustang. I'm having problems with the clutch which is hydraulic. There is no cable. It has a slave cylendar that works as the through out bearing. Can't get to it unless you drop the transmission. There is no bleeder valve anywhere within the system. They only way to 'Bleed" the system is to use a vacuum pump on the resivoir. I tried disconnecting the line going into the slave cylendar, letting all the fluid drain, flush the resavoir with brake cleaner, then bled the brakes and used the vacuum pump. I had a little clutch last night this morning no clutch. I'll try the vacuum pump again tonight but not opptumistic. I shouldn't have to replace the slave cylendar after 10k miles, but anyone who's had or driven an 07 will agree the T5's suck.
Old 06-09-2010, 04:42 PM   #5
Tape's Avatar
this is a pdf file T5 service manual; it will take a couple minutes to download
http://www.ttcautomotive.com/English...0-0199_173.pdf
I always thought all tremec transmissions were cable engaged, sorry
Smell diff fluid or tranny fluid when I get on it? ajpturbo 1996-2004 Mustang GT 0 06-19-2010 09:26 AM
power steering flush 968 1996-2004 Mustang GT 0 06-30-2009 09:20 AM
Transmission Flush runvsofthisbull Pre-2005 V6 Mustang 13 06-26-2008 11:01 AM
How to: Steering Fluid Flush? cagedthought Pre-2005 V6 Mustang 2 10-24-2004 09:30 PM
radiator flush time 6erstang Pre-2005 V6 Mustang 21 08-17-2003 06:53 PM
04:53 AM
