Adjusting the Clutch - Mustang Evolution
Old 06-08-2010, 03:58 PM   #1
Anyone know how to adjust the clutch on a 2000 v6 ?!?! any help is appreciated.
pringle9666 is offline   Reply With Quote
Old 06-08-2010, 07:09 PM   #2
MonteCitan's Avatar
Re: Adjusting the Clutch
There are two ways to do it - The main way to do it is just put your foot under the clutch pedal and lift up.. Then push the clutch pedal down, and it'll self adjust to the best position..
The other way definitely works better (same effect as pulling up on the clutch pedal, however you can take it a little further) but there is risk involved if you go too far and drive it like that (TOB damage, not fully releasing, etc..) so I won't detail that unless you're really interested..
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 06-09-2010, 09:08 AM   #3
if its real floppy you can do what was said above, I generally like a half inch of play pushing in before the clutch slips (rpms jump up while holding gas constant in X gear going down the road)
Old 06-09-2010, 09:23 PM   #4
1234's Avatar
What's this other way you speak of?
Old 06-10-2010, 08:10 AM   #5
If you lay facing down and poke your head/upper body under the dash, take your right hand and put it above the gas petal on the clutch quadrant then push in the clutch with your other hand. Pull the quadrant outwards toward the back of the car and down (it wont really move you are are just getting ready to hold the quadrant against the movment its about to take)
ease out on the clutch petal slowly and the quadrent will "click" (quite noticable) do this a couple times. The slack is taken up now a bit, adjust as needed by testing via driving (ONLY WAY TO BE SAFE HERE!!!!)
go 55mph hold the gas petal constant with your foot, ease in the clutch and if the rpms dont jump up till you are pushing in the clutch 3/4 of an inch~ then you should be good to go. The clutch petal should be firm at the top~ but remember not to tight@
If you ever shift really hard (slam the clutch petal down) or lift up on the underside of it it will unadjust itself
Old 06-10-2010, 01:08 PM   #6
Thanks a lot spector i will try that out
Old 06-11-2010, 12:35 AM   #7
MonteCitan's Avatar
I would say do NOT NOT NOT do this a couple times to start with, you can and will damage things if you go too far
One notch is enough to make a noticeable difference, 3+ is usually overkill
Old 06-12-2010, 12:27 AM   #8
OsirisGuy's Avatar
I'm sorry Spector but I have to do this, I just read a post without a single period so I'm taking it out on you.
Petal vs. Pedal
Yes I am being the spelling and grammar police.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 06-13-2010, 10:18 PM   #9
1234's Avatar
SpectorV worked like a charm. appreciate the info
Old 06-14-2010, 07:16 AM   #10
On my 01 v6 (seems for some reason it needed more adjustment than other cars~) had TONS of flop. It took 3 clicks for mine~ so as said always test and make sure you didnt take up to much slack.
Old 06-14-2010, 11:18 AM   #11
1234's Avatar
It took 2 on mine. But it works great now.
Adjusting Idle and Timing sonicpony03 Pre-2005 V6 Mustang 1 07-23-2008 08:14 PM
adjusting the carb on an 82 GL? I_luv_HP&trq Pre-2005 V6 Mustang 8 09-28-2005 12:14 PM
best clutch ? jedwards242000 Pre-2005 V6 Mustang 5 04-09-2005 03:21 PM
adjusting the clutch? Murph00 Pre-2005 V6 Mustang 4 01-27-2005 05:02 PM
?adjusting the cam position sensor? Horse Pre-2005 V6 Mustang 24 10-18-2004 06:01 PM
» Members Mustangs
Mustang
UB2PED
"Red"
Labrat
Add your Mustang
09:02 PM
