05 trunk release button - Mustang Evolution
Old 06-08-2010, 04:54 PM   #1
obxdude018's Avatar
Ok a while back the remote button to open my trunk quit working on both remotes, so I doubt they are the problem. Any body have a clue on where to start, maybe the solenoid for it or a fuse.
Thanks
_____________
'05 V6 Torch Red with dual stripes, Custom Tune with CAI, FRPP T-Lock, Motive 4.10 gears, Axleback exhaust, sequential tailights, 1/4 window louvers, door scoops
obxdude018 is offline   Reply With Quote
Old 06-08-2010, 05:06 PM   #2
hottcobra's Avatar
Re: 05 trunk release button
check for any blown fuses. check for power and ground at the release.
Old 06-08-2010, 05:20 PM   #3
Loc: Austin,TX
How bout a battery for that remote? Also see if u have the window roll down option. Double click like you are goin to unlock both doors and on the 2nd click hold the button down. Some 05's had this option,I sold my 05 in less than a month after buying it so I never got to check it.
Old 06-08-2010, 05:33 PM   #4
obxdude018's Avatar
I have checked all the fuses that have any relevance to the trunk and any components back there, they all were ok. The remote works with every other command, door lock/unlock, alarm, but the trunk release doesn't work.
Old 06-09-2010, 10:46 PM   #5
OsirisGuy's Avatar
I would check all your fuses. Make sure the car is off, and pull out the fuses individually (except any SRS fuses, if equipped). IF the interior is good then check under the hood.
Another way to start trouble shooting is to put your ear up to the trunk latch and click the trunk release. Listen for the solenoid, or a "click". If there is no click there is most likely an electrical problem.
Additionally you can try making sure the car is unlocked first and then pop the trunk. I've come across keyless entries which will not pop the trunk unless the car has been unlocked first, otherwise the trunk would not open or the alarm would go off.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
05-09 Trunk Release Button 05bluestang 2005-2010 Mustang GT 21 08-13-2016 10:44 AM
how to install a trunk button in 05-09 mustang hottcobra 2005-2010 Mustang GT 2 05-06-2009 12:29 PM
Trunk Button?! Dark04ShadowV6 2005-2010 Mustang GT 12 05-01-2009 01:29 PM
where does your clutch release eagle05 1979-1995 Mustang GT 10 06-15-2007 02:52 PM
12:24 PM
