bad squeaking noise on 3.8 01' mustang - Mustang Evolution
Old 10-15-2006, 01:55 PM   #1
i have a problem with a bad squeaking noise and i dont know where its coming from. i have 01 mustang 3.8 and its sounds like its in the area where the water pump is, but my car doesnt run hot and its not leaking any antifreeze can somebody help me wit the problem???
jumpman1203 is offline   Reply With Quote
Old 10-15-2006, 04:06 PM   #2
Re: bad squeaking noise on 3.8 01' mustang
Does the sound get worst when you turn the steering wheel? Also, what exactly does it sound like, could be several things.
Old 10-16-2006, 12:15 AM   #3
it just squeaks the sound is like a bad serpentine belt, no i doesnt matter if i turn the wheel or not it still squeaks.
Old 10-16-2006, 12:41 AM   #4
Have you checked your belt? Also, look to see that all the pulleys are turning when the car is running, might be a locked pulley.
Old 10-16-2006, 12:45 AM   #5
all the pulleys are fine and the belt looks good
Old 10-16-2006, 07:41 AM   #6
Sexylil66's Avatar
My '00 3.8 squeaks when i am sitting still and turn the steering wheel...what does that mean?
My Friends On A Saturday Night After 6 Shots, 3 Martinis, 2 Pitchers of Beer :drinkbud: I love being the DD
Sexylil66 is offline   Reply With Quote
Old 10-16-2006, 04:08 PM   #7
I'd recommend starting a new thread, but first off, check your fluid in your power steering pump, if it's low, add some. They're notorious for going out.
Old 10-16-2006, 07:51 PM   #8
Sexylil66's Avatar
okay thanks
Old 07-22-2015, 08:29 PM   #9
The cam sensors are bad to squeal on the earlier ones,looks like same thing.knowing ford it hasn't been fixed
ALLYDRIVER1 is offline   Reply With Quote
Old 07-27-2015, 01:03 AM   #10
Mine made the same noise...a buddy replaced the tensioner pulley or idler pulley...not sure which one lol. The little wheel at the top front of the engine and noise was gone!
FrankTheTank is offline   Reply With Quote
Clicking Noise kind of Squeeky Noise... braumab 2005-2010 Mustang GT 23 06-29-2008 11:24 PM
Squeaking Noise joekool9 Pre-2005 V6 Mustang 3 08-03-2004 09:38 AM
Difference between 99' and 01' Cobra? audioqueso The Bar 27 11-19-2003 08:26 PM
looking for an LCA that will not bind and make noise bad? SpectorV Pre-2005 V6 Mustang 1 05-05-2003 06:38 PM
11:37 AM
