tach problem - Mustang Evolution
Old 10-17-2006, 09:16 PM   #1
tach problem
the needle on my tach has been jumping bad lately. not to higher numbers, but jumping between working and not working. sometimes it wont work for quite awhile but if i hit a hard bump, bass from my music hits hard, or i tap on the instrument cluster cover it will go back to working. sometimes too it wont always go to "0" when it isnt working. it will go down but not all the way.
do i need to get a new /or used instrument cluster or could there just be something wrong with the needle. ive had my local shop check it out and they think i need to get the new/or used cluster but i dont really want to.
cash05_mustang is offline   Reply With Quote
Old 10-17-2006, 09:22 PM   #2
bbunt302's Avatar
Re: tach problem
You either have a shorted wire or the needle on the tach is hanging. Either way, it should be simple to fix without swapping out the entire instrument cluster.
Scary stuff.
Old 10-17-2006, 09:26 PM   #3
Re: tach problem
ive been wanting to put in BBK's cobra white faces, if i put those in do you think it could possible fix it if it was the needle
and how hard are those white faces to put in
Old 10-18-2006, 06:34 PM   #4
Re: tach problem
I really don't think adding an overlay will help any. What you could do, however, is take the cluster out of the car and set the needle out a little further by using a needle puller. This may keep it from hanging up.
Old 10-18-2006, 07:16 PM   #5
Re: tach problem
sorry i shouldve been more clear on saying that the overlays would help. i was kinda getting at would it help because i would be messing with the needle like u are saying to do
tach ? gearbanger67 Classic Mustangs 4 04-14-2007 08:06 PM
Installed Tach 98 Gt SilverStang96 1996-2004 Mustang GT 11 02-19-2006 01:08 AM
Tach not working... SilverStang96 Pre-2005 V6 Mustang 3 11-12-2004 12:34 PM
07:15 PM
