5.4 navigator into a v6 02 mustang - Mustang Evolution
Old 10-18-2006, 05:04 PM   #1
can you put a 5.4 navigator engine into a v6 02 mustang? we have clearence and mounting bractets are alright...i i dont have wiring for the engine/transmission, the right fuel lines/setup for the fuel rails i have, and dont have the right setup for the coolant hoses. can i get all that for the car and will it all work?
auddy lou is offline   Reply With Quote
Old 10-18-2006, 05:46 PM   #2
Re: 5.4 navigator into a v6 02 mustang
Yes. My roommate's uncle put at twin screwed navigator dohc 5.4 and t56 into his 01 gt, same chassis, it'll all fit.
Old 10-18-2006, 05:48 PM   #3
but will it all work?
Old 10-18-2006, 05:49 PM   #4
Yeh, he ran his for a while before selling it. You'll spend alot of time and money on the small odds and ends.
Old 10-18-2006, 05:55 PM   #5
what about the coolant/fuel lines, what parts to use and where do i get them?
Old 10-18-2006, 05:55 PM   #6
That I couldn't tell you...I didn't see him build the car.
Old 10-18-2006, 05:56 PM   #7
what did he use for wiring and what did he use for coolant lines and what did he use for fuel lines/fuel rails?
Old 10-18-2006, 05:57 PM   #8
could you ask him? its kindda urgent
Old 10-18-2006, 05:58 PM   #9
You're gonna need a factory ecu in order to run the 5.4 then get it tuned for the engine. I can tell you that much. As far as contacting his uncle, I have no way to, He's in kansas and i'm in mississippi
Old 10-18-2006, 05:59 PM   #10
this is for my b/f im trying to help him out and trying to find answers for him is there anyway i could talk to you over aol or msn or maybe even talk to you roommate's uncle?
Old 10-18-2006, 06:02 PM   #11
and he doesnt know where to get the wiring for the engine
Old 10-18-2006, 06:28 PM   #12
i'm sure if you google "factory wiring harness ford 5.4" you will pull up something
Kyle is offline   Reply With Quote
Old 10-18-2006, 10:22 PM   #13
crazeflier07's Avatar
Send a message via AIM to crazeflier07
Do you have any issues with hood clearance? I read something about the 5.4 Triton motor (i think) being out in a 01 gt and the top of the motor needed to have the hood cut to clear the couple inches. I think it was an article in FF&MM. Lots of torque!!!
Sinister Six
1998 3.8L V6
Done So Far:
~CAI, True dual exhaust, UDPs, MGW Shifter, H&R springs, Stage 1 & 2 supension kit, performance rotors & pads, steel braided lines, 1 inch rear spacers, A.R. Rebel 17x9s with BFG rubber! :thumbs2:
crazeflier07 is offline   Reply With Quote
Old 10-18-2006, 10:24 PM   #14
just got a different hood that had bit more of a rise to it
Old 10-20-2006, 02:59 AM   #15
Region: Hawaii
It will drop right-in. Just like swapping a 4.6. The custom items needed will be Intake runner adaptors if you want to run a N/A Cobra intake. a new hood. Exhaust manifold extension to X or h-pipe, or custom headers. You might need a new fuel pump. Besides that anything and evrything that is needed to swap in a 4.6.
99 Atlantic Blue V6- SOHC 4.6 swap, Tremec 3650, 8.8 rear end/ Flowtech Ceramic LT headers, off-road x-pipe, Spintech side exit exhaust. K&N drop in filter, removed snorkel, 18x10, 18x9, Anthracite Bullitt Replicas 295-35's, 265-35's. Eibach Pro-Kit springs, M&M Camber Plates
wrecked2001 is offline   Reply With Quote
Old 10-23-2006, 05:59 AM   #16
You can swap it in, any v8 computer and wiring could be set up to run it, cobra or GT. Both are COP, and most 99+ are COP as far as I know.
Justin Starkey
2007 Shelby GT500 705RWHP/708RWTQ
2000 Mustang 3.8 A4 TT 450RWHP/475RWTQ 10.996@127 17psi stock 3.8
2006 F250 CC 4x4 6.0L 14.3 @ 93
2006 Mustang 4.0 M5 Vortech 13psi 395RWHP/374RWTQ wife's car
justin00stang is offline   Reply With Quote
Waay cool commercial, Lincoln Navigator RGR The Bar 13 06-16-2006 06:17 AM
10:54 AM
