2000 V-6 Idle air control noise - Mustang Evolution
Old 06-16-2010, 07:55 PM   #1
Heres the info
I had a head gasket leak. So I had the heads shaved, new bolts, head gaskets, intake manifold gasket, new plenum gasket, new lifters and push rods.
Put it all back together and have a loud hooting noise from the AIC. If you unplug it it stops. Of course the car won't idle unplugged.
Put on a new IAC, Mass air sensor. Still there.
Took it the the Ford garage, they say all sensors are working within normal ranges. They have had it two weeks and can't find the problem. They put a new IAC gasket on, and new throttle body gasket. Still got the loud noise. It does go away abov 3000 rpms.
He think it is a bad intake manifold gasket?
Any advice? Anyone else ever have this problem?
spgeid is offline   Reply With Quote
Old 06-17-2010, 01:48 PM   #2
1234's Avatar
Re: 2000 V-6 Idle air control noise
Could be the gasket or when you put the intake back on you could of cracked it.
Quick test is start the car and spray starting fluid around the sides of the intake where it meets the head and if it revs up you either have a bad gasket or intake. If that dont work let me know.
Old 06-17-2010, 07:14 PM   #3
Do you think I cracked the plenum intake or the intake manifold?
Old 06-17-2010, 07:23 PM   #4
Its a v6 right? Our manifolds arent plastic so I doubt that its cracked. And the manifold and plenum are built together.
tigerfan2771 is offline   Reply With Quote
Engine Noise @ 2000 RPM + megax29 Pre-2005 V6 Mustang 8 08-28-2008 02:26 PM
Clicking Noise kind of Squeeky Noise... braumab 2005-2010 Mustang GT 23 06-29-2008 11:24 PM
Noise reduction for fender well mounted Cold Air Induction Brent Pre-2005 V6 Mustang 18 01-29-2006 10:04 AM
02:28 PM
