I got engine trouble - Mustang Evolution
Old 10-29-2006, 12:26 AM   #1
Send a message via AIM to BigL34461
the other day i was a that light and my car(2001 v6) just started sputturing and it backfires the check engine light started flashing. i got the code checked and it came back misfire in cylinder #5 i changed all spark splugs cleaned the air filter. and still the same problem. i'm going to try the fuel filter next since i don't remember ever having it done. i checked the wires.... i didn't see any arching. Any suggestions??
BigL34461 is offline   Reply With Quote
Old 10-29-2006, 12:15 PM   #2
bbunt302's Avatar
Re: I got engine trouble
I would place my bet on the coil pack. There's a lot of things that could cause it, but the coil pack seems to be the most common thing I've seen cause it on the 3.8s.
Fuel filter, fuel pump, bad injector are all also possibilities.
Scary stuff.
Old 10-29-2006, 12:51 PM   #3
I vote for coil pack as well. My car did the same thing and that was the problem.
Old 10-29-2006, 02:49 PM   #4
rocknbronco's Avatar
try a oxygen sensor had the same thing on a sable a few weeks back
Mustang wanted for here...
rocknbronco is offline   Reply With Quote
Old 11-06-2006, 01:34 AM   #5
What was the code by chance?
Old 11-06-2006, 07:13 AM   #6
do you have an underdrive pulley?
Old 11-06-2006, 07:31 AM   #7
Dont remmeber off hand I do know if is a coil pack replace them all and replace the plugs becasue sometimes a plug will read as a coil miss fire
Also give those E3 plugs a shot my customer tried em out and loves em havent seen em in a Ford V8 yet might use em in mine funny thing is they come with a 5 year warranty
Old 11-06-2006, 08:25 AM   #8
MonteCitan's Avatar
p0305 would be misfire cylinder 5, Could be injector, wire, coil, or something internal causing issues (piston, compression, valvetrain problems..)
but more likely its a wire, coil or injector..
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 01-09-2007, 04:30 PM   #9
snowtrucker3 is offline   Reply With Quote
Old 01-10-2007, 10:03 PM   #10
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
It wouldn't be the pump. That wouldn't cause only one cylinder to misfire.
More likely it's a wire or injector. It is also possible that it could be the coil pack. You need to do a spark test. Hook up a tester to #5 wire and see if it's throwing a spark. If not, it's your wire or coil pack. If it is, I'd say it's probably the injector.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 01-12-2007, 11:34 PM   #11
Titus Wadicus
svtlx's Avatar
im shoot for wire...my escort pulled the same **** om me last month wit the misfire code.
Too much trouble? upton7 1996-2004 Mustang GT 4 07-15-2009 08:31 PM
So...how much trouble am I going to get into? lowflyn The Bar 12 04-14-2009 06:33 PM
Engine trouble stangman81 1996-2004 Mustang GT 9 03-22-2008 07:40 PM
95 5.0 trouble starting? blackvert18 1979-1995 Mustang GT 0 01-04-2008 09:04 AM
Looks Like some of us are going to be in trouble!! ComputerGuy The Bar 23 01-16-2006 08:49 AM
03:33 AM
