best CAI - Mustang Evolution
Old 10-29-2006, 08:24 AM   #1
best CAI
Ive got an 06 and looking for a nice polished CAI. All I can find are the black plastic ones. Id like to have some chrome under the hood. Does anyone make a polished one? Im about to go look over at AEM unless someone knows of a better one. I have an AEM CAI on my 99 Si (B18C1 swap) and have loved it.
Also, is there noticeable throat with a CAI? Seems to me the 4.0L must sound pretty nasty with the intake opened up. My B18C Si had drastic differences with one.
1quikV6 is offline   Reply With Quote
Old 10-29-2006, 10:53 AM   #2
Re: best CAI
On my Mustang I can't hear my intake hardly at all. Nothing like it was on my old GSR.
AEM makes some very nice intakes, here are some more.
Cold Air Kits - 05-07 Mustang
JROC is offline   Reply With Quote
Old 10-29-2006, 11:56 AM   #3
05STANG's Avatar
Region: Nevada
Re: best CAI
I have a MMR and it's throaty, overwhelms my exhaust note which I like, but if I had to do it again I would go K&N plastic it runs cooler and cooler means HP.
I COULD HAVE HAD A V8
05STANG is offline   Reply With Quote
Old 10-29-2006, 12:19 PM   #4
Send a message via AIM to XxViSiOnxX Send a message via Yahoo to XxViSiOnxX
Re: best CAI
http://www.knfilters.com/search/prod...Prod=69-3522TP
Heres a Chrome One By a Reputable Company Give a Little Less Than the Black Plastic In rwhp but i think its still worth taking a look at
XxViSiOnxX is offline   Reply With Quote
Old 10-29-2006, 01:23 PM   #5
iwannagofast's Avatar
Re: best CAI
The K&N Typhoon is chrome. Dont buy some knock off ebay one!
iwannagofast is offline   Reply With Quote
Old 10-29-2006, 02:09 PM   #6
Re: best CAI
Yeah JROC my B18C is alot louder with an intake than stock.
I just figured with the LS1 style front mount intake that it would be much throatier.
As far as plastic versus chrome... Id just like something to look at under the hood than more PLASTIC... who wants to pop the hood and look at more of that than is already there? I'll sacrifice a few horses to look good.
2007 Mustang V6 Black/Black
Pony Package/GT rims/Shaker1000/MyColor gauges/5 speed/leather
1999 Civic Si Black/Grey
Built 13.1:1 compression B18C1
Old 11-03-2006, 12:53 AM   #7
rmays06's Avatar
Re: best CAI
Tunable inductions from DeMoulet is sweet. Painted to match and easy to install. You can get the CAI and XCAL2 for $525,
Car: 2006 Tungsten Grey, Mustang Side Louvers, White Brake Calipers, Flowmast Axle Back, TI CAI XCAL 2, Dyno tune by Alt Auto, many look good mods interior and exterior.
www.tungstengreyregistry.com member #001
My Ride
rmays06 is offline   Reply With Quote
Old 11-03-2006, 08:45 AM   #8
Re: best CAI
Wheres your Mass Airflow Sensor?
Old 11-03-2006, 08:14 PM   #9
rmays06's Avatar
Re: best CAI
There is a cut out in the rear of the CAI with a little piece of metal to screw into. It goes right in. Nice set up I tell you.
My Ride
Old 11-03-2006, 10:54 PM   #10
Re: best CAI
For $500 it better do more than look good... thats just utterly expensive...
Even if it nets 15-20hp thats still a good chunk of change...
Old 11-03-2006, 11:01 PM   #11
Re: best CAI
JLT is the end all solution, but I just realized you have a 6 and they don't make one for the 6.
Old 11-04-2006, 07:18 AM   #12
bbunt302's Avatar
Re: best CAI
That's with an XCAL and a tune as well though, if I read his post correctly.
Scary stuff.
Old 11-04-2006, 12:43 PM   #13
Re: best CAI
Still $500 and can have a dual cat back setup and net the same horsepower.
Old 11-04-2006, 12:44 PM   #14
bbunt302's Avatar
Re: best CAI
You won't get as much power from dual cat back as you will from a CAI and a good tune.
Scary stuff.
Old 11-04-2006, 12:50 PM   #15
Re: best CAI
a "good tune" is one that involves a dyno. And if you did exhaust and a dyno spin you'd net more hp.
Old 11-04-2006, 01:28 PM   #16
bbunt302's Avatar
Re: best CAI
Actually, you can get good tunes for a pretty much stock car with a "canned" tune. It's not like a heavily modified car where things are always different. Stock cars are all pretty much the same. There are minor differences, but that's accounted for in the tune. They will be a little safer than a dyno tune, but I would personally rather have a safe tune and compromise a couple horsepower anyway.
I've seen gains of 25 rwhp on the GTs with just a tune and CAI. I would think the V6 could at least see 15. I can guarantee you that you won't see that with dual exhaust. Maybe 5 at the most.
Scary stuff.
Old 11-04-2006, 01:58 PM   #17
Re: best CAI
500 is just still steep... maybe thats why I have the Honda... bang for the buck...
Old 11-04-2006, 07:10 PM   #18
Kiljosh's Avatar
Re: best CAI
Im going to jump in and say this,
CAI is a CAI. I can see the whole plastic holds less heat = more power theory but anyway you look at it all your doing with a CAI is trying to minimize restriction in the intake.
Any piece of smooth tubing with minimal bends will suffice...
Meaning, yes, buy off Ebay if you are prepared to make it fit or maybe send back to get the right part. But spend as little as possible on your CAI and actually buy a mod worth doing, like that tuner everyone is talking about.
Old 11-10-2006, 10:58 PM   #19
rmays06's Avatar
Re: best CAI
Seeing as you know it all this probably won't make any difference but duals on the V6 make about +10 Hp depending if you go with X or H. The XCAL and TI CAI I have run$525 and I'm pushing close to +25 HP. Yes you do need a Dyno tune but if you get tuner who works with the CAI and XCAL systems he can set up a tune that will push plent of power. Running close to 205 HP with my $525. Not bad. But having a HONDA you probably wouldn't understand.... you know band for the buck (chrome tip and neon lights)
My Ride
Old 11-10-2006, 11:26 PM   #20
Zim
You want to **** me?
Zim's Avatar
Re: best CAI
The reason CAI's come with the xcal and a tune is because apparently these 05+ stangs computers are pretty set in there stock working order and dont like much change. Even something as small as an intake requires a tune. It sucks, but its the truth.... The good thing is, you'll have that XCAL forever and you can always dial in dyno tunes later down the road as you add more to your car. :dunno:
I like toys
Old 11-12-2006, 09:57 AM   #21
Re: best CAI
chrome tip and neon lights? lmao... for one its a full Apexi exhaust. Two, its a built B18C from a GSR integra, THREE neons never really did it for me.
I think there are more neons on riced out SN95 V6 Mustangs than Hondas to be quite honest with you. I dont have a body kit, or a wing, hell its pretty much stock on the outside aside from Si rims and a jdm grill kit.
Why does everyone think that just because someone owns a Honda that they "rice" it out. I think you're terribly mistaken. I bought the Mustang because it was a good deal and i love the way it looks and turns heads. If I wanted power Id have gone for the GT but why have two cars in the low 13's and pay the insurance on a GT.
Old 11-12-2006, 03:59 PM   #22
rmays06's Avatar
Re: best CAI
Well after reading you post I see you don't understand. I'm sorry! This is about CAI and XCAL!
Why becuase it a honda!
My Ride
Old 11-12-2006, 06:32 PM   #23
Re: best CAI
lol Hey Hey now, Yes I own a Honda and Yes its fun but I do love my mustang. I just went through a phase for a while where Id spend half of my time building B series Honda engines in the garage instead of living my life lol. I grew up with Mustangs and various fords,mstly building 302's with dad my entire childhood. I just take a liking to my Civic. Might not be much but Im the type of guy that if its got 4 wheels and its fast then its cool by me as long as in doesnt look like an APC catalog on wheels. Put the money under the hood.
Old 11-12-2006, 06:44 PM   #24
Re: best CAI
I understand this is a Ford site but not all of us just own Fords. I am loyal to my blue oval but I do have a tendency to do the "rice" thing here and there if you will. My garage isnt full of small block fords, its more like a dumping ground for japan but hey, I hate riced out civics with mismatched bodykits and Pep Boy rims just as much as you do.
Yes I feel bang for the buck lies with the little ricers. I myself have been stomped in my SC by more than one "ricer". Just dont hate me for owning a Honda or for my garage looking like this....
Old 11-15-2006, 12:02 PM   #25
project_v6's Avatar
Re: best CAI
WOW! Is this an H22A? I hava a B16A engine on my 99 civic way back in Manila, with a few mods done to it.
This h22 nets like 210HP. Is that right?
PROJECT V6
project_v6 is offline   Reply With Quote
Old 11-16-2006, 07:55 AM   #26
rocknbronco's Avatar
Re: best CAI
Check on ebay for a cold air intake and see what you can get for minimal money then place a K&N filter on it
Mustang wanted for here...
rocknbronco is offline   Reply With Quote
Old 11-18-2006, 09:44 AM   #27
rmays06's Avatar
Re: best CAI
You have to place the MAF sensor in it somewhere on these thing so our cars run the right way. Then you need to make sure the tubing isn't to big or too small. Measurments are a must. Becareful if you go this route.
My Ride
Old 03-19-2007, 11:37 AM   #28
Re: best CAI
I have a K-N typhoon on my 05 and it works just fine. You can hear the intake when you really get down on the pedal. all so put throttle body space with it. no need for a reflash either. be sure to get a recharge kit to clean and reoil the element. have put 30,000 miles on mine with no problems.
stang05blue is offline   Reply With Quote
Old 03-19-2007, 11:40 AM   #29
Re: best CAI
i have a typhoon on my 05 and it worksfine. sounds nice when flogged. no need for reflash, get recharge kit to keep it clean.
cai
afe stage 2 cai or C&L racing cai b's stang 2005-2010 Mustang GT 5 05-20-2010 06:25 PM
CAI Taywi Pre-2005 V6 Mustang 17 06-30-2007 08:45 AM
need a cai mustang0386 Mustang Parts for Sale and Wanted 4 12-03-2006 08:33 PM
Cai. Seph Pre-2005 V6 Mustang 15 06-21-2005 05:32 PM
98 V6 Cai Ibanezplayer272 Mustang Parts for Sale and Wanted 3 12-05-2004 05:32 AM
10:41 AM
