monroe struts/shocks - Mustang Evolution
Old 06-18-2010, 02:53 PM   #1
Send a message via Yahoo to Senorjizzy
my grandma is trying to lure me away from installing my struts and shocks myself, so she is taking me to get a quote from her friend that owns the firestone shop here. and he is saying that he would order the number one brand. which is in this case Monroe. do you have any information on these. im reluctant to order these.
maroon 1998 mustang V6 auto. AM cai. Raxiom black headlights )
Senorjizzy is offline   Reply With Quote
Old 06-18-2010, 03:44 PM   #2
Re: monroe struts/shocks
well its not as simple as a shock/strut its about valving vs spring rate and the weight of the car etc etc etc. If you plan to just normally drive the car, not worried about performance (to a high level) then you have many options.
Search for Tokico, OEM ford, etc contact tousleyfordparts.com (call em) and get a quote as well.
Shock/Strut install is QUITE easy if you plan to do it then also do springs. The only real issue is getting the strut nut and shock nut off~ requires a helping hand from a friend to hold the top of the strut still while you remove/install the nut~ can be tricky. If you have air tools its MUCH easier.
Old 06-18-2010, 09:12 PM   #3
Also be careful if removing the springs after you lower the A-arm. You will probably "decompress" via lowering with a jack, so they still keep a considerable amount of energy. Wouldn't want them shooting out and hurting someone.
Other than that (and the strut nut), the install isn't too bad...just take your time and have a friend or 2 along to help.
Old 06-18-2010, 09:21 PM   #4
Also, if you decide to have them installed, check with the guy at the Firestone shop and see if he'll install parts other than Monroe.
If you want more performance oriented shocks/struts then go with tokicos from NQS...but if you want OEM styled ones that are basically the same as your stock ones, Monroe is probably your best bet.
Usually if you're lowering the car you'll want performance oriented products like tokicos or bilsteins to handle the change in spring rate - caused by the more aggressive aftermarket springs. Keeping OEM styled or stock equipment will lead to them wearing out much sooner.
Old 06-19-2010, 12:25 AM   #5
well i hadnt considered that :< if i buy the Tokico's, or a "performance" strut/shock, i Will need different springs?
Old 06-20-2010, 12:47 PM   #6
I would think the aftermarket shocks/struts would be fine with OEM springs, but it never hurts to replace them with some more aggressive ones...generally shocks/struts "wear out" well before springs start having issues so that's why it's so important to get new shocks/struts if you get lowering springs.
You get added performance when combining the aftermarket shocks/struts and springs, and they will lower the car 1"-2" depending on the style.
If your car has higher miles and has been on some rough roads, the springs may have started to sag a little bit and lost some of their rate...in which case you'd want to get some new ones.
Old 06-21-2010, 07:20 AM   #7
if you are going through the effort of putting in shocks/struts install springs as its the same basic amount of work and should NOT cost you much more (like 20-50 bucks over the shocks/strut install for springs)
Thats how you can tell if a place is ripping you off, get a quote for shocks/struts install then ask for springs as well. If they up charge you more than they should you know one of two things. They are ripping you off or they dont know what they are doing enough to know how much extra work goes into springs vs shocks/struts... neither of which you want to be a part of.
Old 07-12-2010, 11:21 AM   #8
Foxone's Avatar
I would stay away from the monroes, I did a full set, one leaked the next day, they feel pretty crappy to me.
Foxone is offline   Reply With Quote
Old 07-12-2010, 05:17 PM   #9
im not one bit impressed. but they are already on, and they didnt but the caliper bolt back in. so were suing lol :>>>
SHOCKS/STRUTS Gt.Vert 1996-2004 Mustang GT 16 04-28-2010 08:15 PM
Struts and Shocks xcxm049 Pre-2005 V6 Mustang 11 03-05-2010 12:59 PM
shocks and struts all8280bcc 1996-2004 Mustang GT 8 03-01-2007 12:49 PM
Shocks Struts megax29 Pre-2005 V6 Mustang 11 07-12-2006 09:34 PM
Shocks..struts Exit_In_Red Pre-2005 V6 Mustang 6 12-01-2004 10:33 PM
05:43 AM
