Free 05 V6 Mod test - Mustang Evolution
Old 11-01-2006, 11:33 AM   #1
05STANG's Avatar
Region: Nevada
Free 05 V6 Mod test
O. K so I did the mod a couple days ago,
A Hot Body I did not cut any hoses, just disconnected them and bought high temp hose to do the bypass.
Results: I have not run it at the track yet, but what a difference. Before the mod, as my car would warm up I would get throttle lag and if I punched it I would get an instant single knock and a little ping in the upper RPM,s I have the Diablo tune with 4 degree's of global timing advance and even on 91 octane she was pinging above 4500 rpm the CAI (MMR) was hot as hell and of course you couldn't touch the throttle body.
So after 150 mixed miles in 80 degree Vegas temps, no ping or knock, instant throttle response and the throttle body and CAI are actually just warm to the touch even after sitting in traffic. Now while there is no HP gain to this mod I am sure the previous heat buildup was costing me about 10 HP I am now going to start running the Higher Performance Tune and report back.
I COULD HAVE HAD A V8
05STANG is offline   Reply With Quote
Old 11-03-2006, 12:43 AM   #2
rmays06's Avatar
Re: Free 05 V6 Mod test
Sounds like a good way to f' something up. If not done perfect!2:
Car: 2006 Tungsten Grey, Mustang Side Louvers, White Brake Calipers, Flowmast Axle Back, TI CAI XCAL 2, Dyno tune by Alt Auto, many look good mods interior and exterior.
www.tungstengreyregistry.com member #001
My Ride
rmays06 is offline   Reply With Quote
Old 11-03-2006, 01:18 AM   #3
It sounds like a good idea to do it though. Pretty bad design if you ask me.
Old 11-03-2006, 09:36 AM   #4
05STANG's Avatar
Region: Nevada
What can you F up? simple bypass hose and 2 clamps. Easiest mod I have ever done and it actually works. Now I really do have a cold air intake. Ford should do a recall of the 05 V6's and do this, the car runs great now.
Old 11-06-2006, 12:19 PM   #5
Region: Nevada
did this this weekend . easiest free mod i have seen , just loop the one hose back to the heater lines . does seem better when warmed up
gasman66 is offline   Reply With Quote
FREE Performance Mod megax29 Pre-2005 V6 Mustang 16 09-18-2004 05:01 PM
03:59 PM
