engine code p0102 and p0113 - Mustang Evolution
Old 11-01-2006, 03:14 PM   #1
Send a message via AIM to BigL34461
i've changed spark plugs and wires, fuel filter, cleaned maf with crc maf cleaner. cleaned air filter.....i car still doesn't run right it lacks power sometimes from takeoff then finally kicks in around 2500-3000 rpm. Sometimes when it idles rpm dives to 500 it also does when the fan comes on. went to autozone and these are the codes that came up. are maf and iat sensors bad?? I just started having these problems.....Someone please help. I really don't want to go to a shop because i have feeling it going to cost alot
BigL34461 is offline   Reply With Quote
Old 11-01-2006, 05:49 PM   #2
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
Re: engine code p0102 and p0113
OBD-II Powertrain Diagnostic Trouble Codes (0102-0812)
Looks like it could be a bad maf even though you cleaned it. I'd think that's where your bad idle comes from. p0113 is for the iat sensor so maybe that needs to be cleaned or replaced.
I know where you can get a used maf from a 2002 V6 for cheap if you want. pm me.
99 Cobra: flowmasters, 18x9.5 cobra R's, soon to be tuned and geared. daily driver
99 V6:in avatar, Mac Cai, true duals/flowmaster 40's ,UDP, custom tuned, bullitt suspension 18" wheels...taken by mother nature
I_luv_HP&trq is offline   Reply With Quote
Check engine code- p1443 embecker Pre-2005 V6 Mustang 7 05-12-2014 12:22 AM
P0301 engine code White Stalion Pre-2005 V6 Mustang 7 01-19-2011 08:26 PM
check engine light misfire code 98stang460 1996-2004 Mustang GT 6 07-27-2010 08:27 AM
check engine light code help p0102 HELP! slow98gt 1996-2004 Mustang GT 1 05-21-2009 01:52 PM
06:02 PM
