Need part numbers - Mustang Evolution
Old 06-21-2010, 01:19 PM   #1
Need part numbers
I got a 04 3.9 V6 mustang and I need part numbers for a throttle body, headers and a cold air intake. I can find for the 3.8 but need to know if they will fit the 3.9
firemen58 is offline   Reply With Quote
Old 06-21-2010, 01:21 PM   #2
Re: Need part numbers
Its the same engine. yes, they will fit.
Old 06-21-2010, 01:32 PM   #3
can u give me some other parts i can get to increase hp...this is my first mustang
Old 06-21-2010, 01:39 PM   #4
Here is a good place to start to kind of get your head wrapped around what is all available.
http://www.mustangevolution.com/forum/t5654/
What your ultimate goals are will dictate what is best.
Old 06-21-2010, 02:11 PM   #5
will the fit on the 04 3.9?
Mustang V6 Cold Air Intake Kit (99-03 V6)
Item #: 14002
Market Price: $84.99 - You Save 12% ($10.00)
Our price: $74.99
Availability: Ships the same business day.
Avg. User Rating: Read Reviews
Quantity:
112 customer images
Product Features Quick Facts
Increased Horsepower and Throttle Response.
Reusable High flow Air Filter.
Polished Aluminum Finish.
Simple Installation.
Fits 1999 to early 2003 V6 Mustangs.
Replace the stock restrictive air box in your V6 mustang with a Cold Air Intake for an increase in power that you can feel.
Product DescriptionImproves Horsepower. This Cold Air Intake kit completely replaces the stock factory air box and restrictive paper filter element in your 1999-2003 3.8 V6 mustang with a high flow filter assembly for a noticeable increase in horsepower and throttle response while filtering out destructive power robbing dust particles. This CAI pulls cooler denser air from inside the inner fender well to make more power that you can feel.
Reusable Filter. Included in this kit is a High Flow reusable air filter. So no need to go out and buy a new filter every few thousand miles. Just clean the filter, re-oil it, save money, and go!
Polished Finish. A Cold Air Intake not only improves horsepower and acceleration, but it also improves your mustangs under hood appearance with a striking polished aluminum finish. Now you can have the best of both worlds, performance and style.
Simple Install. Cold Air Intake kits are relatively easy to install with basic hand tools. No extra modifications are required for the installation. See the video below for an overview of the installation process.
Included Hardware.
78mm - 101mm Double Hose Clamp (1)
3.5" - 3" Step Down Coupler (1)
3" - 2.5" Step Down Coupler (1)
78mm - 101mm Hose Clamp (1)
65mm - 89mm Hose Clamp (4)
16" Hose (1)
Gasket (1)
Anchor (2)
Nylon Lock Nut (6)
Bolt (6)
Small Washer (6)
Large Washer (2)
Fender Shield (1)
3" Pipe (1)
3.5" Pipe (1)
Cone Filter w/ Open End (1)
Cold Air Intake Specifications
Year/Model: 99-03 V6 Filter Placement: Inside Fender
Material: Aluminium Finish: Polished
Manufacture: N/A Computer Tune Required: No
Learn More About Cold Air Intake Kits:
Old 06-21-2010, 07:32 PM   #6
Yes, that CAI will fit the 04 3.9 engines just fine...despite AM saying the ranges are from 99-03. Same goes for a throttle body and headers...though those mods aren't necessary nor will they offer worthy performance gains.
Here's an article on the differences between the 3.8 and 3.9:
Comparison: 3.8 vs 3.9 V6 Mustang Engines
Old 06-21-2010, 10:35 PM   #7
ok what about the bbk 65 mm throttle body and bbk shorty headers 65 mm?
Old 06-22-2010, 03:09 PM   #8
Send a message via AIM to VCS_SSSTANG
Both a waste of money.
VCS_SSSTANG is offline   Reply With Quote
Old 06-23-2010, 07:17 AM   #9
yea, headers and throttle bodys for the v6 are a waste anywhere near stock so dont do it.
The only engine difference in the 3.8 to the 3.9 if the internals of the engine, so if you ever built the engine you might care~ thats about it other wise its all pretty much the same.
Cold Air intake
under drive pulley (you get the entire balancer and pulley has to be impacted on not a big deal just FYI)
exhaust (true dual catback is the way to go! 2.25 pipe all the way back as well, like a GT take off factory exhaust)
lower it with wheels/tires
grill delete (mach 1 grill delete kit)
get a custom tune from VMP or someone similar
if a manual trans (i hope so) get a shifter (mgwltd.com) you have a T-5 transmission if manual
your good to go
Does anyone know the part numbers of... Kiljosh Pre-2005 V6 Mustang 1 10-10-2008 07:28 PM
New Procharger numbers ricklmesa Pre-2005 V6 Mustang 19 08-18-2007 05:08 AM
Part numbers? MoOn-BaBy Pre-2005 V6 Mustang 1 10-26-2006 09:36 AM
dyno numbers jedwards242000 Pre-2005 V6 Mustang 7 04-17-2005 03:01 PM
» Members Mustangs
Mustang
fieeug
Mona
56singh
Add your Mustang
04:26 PM
