AIR Pump- Needed? - Mustang Evolution
Old 11-05-2006, 09:36 PM   #1
AIR Pump- Needed?
AIght heres the deal, a couple days ago my check engine light came on, i took it to this place i have gone to before, he ran the diagnostics and said it read that the air pump was malfunctioning, so he reset the ECU saying it may have just been a little defect and if it comes back on come back, so it didnt go back on until the next day, but ive read from a thread here briefly that its a common problem and the aiur pump isnt really needed? i live in florida (no emissions tests)
so what i want to know is should i replace it, could it just be a leak in the hoses to and from the air pump, if its busted and i dont replace it will anything happen to the way my V6 drives? Thanks in advance, any knowledge, suggestions, help greatly appreciated!
DMAC is offline   Reply With Quote
Old 11-06-2006, 01:34 AM   #2
Re: AIR Pump- Needed?
Do you remember the exact error code for it?
Old 11-06-2006, 10:48 AM   #3
No he didn't tell me anything except the only thing that was coming up was the air pump
Old 11-06-2006, 10:57 AM   #4
It should be a p0411 code. You should make them give you the code every time so you don't have to trust them and can do research on your own. They have a tendency to tell you one thing but it be another.
If you do not have emission tests then you don't need it. You can remove it and have the check engine light code turned off if you have a chip/x cal 2.
It is located on the passenger side in the front of the wheel well.
fuel pump for v6 The Darkside Pre-2005 V6 Mustang 11 01-06-2009 09:27 PM
fuel pump?? Xx_1990GT_xX 1979-1995 Mustang GT 7 10-07-2008 06:37 AM
Legal options of a detrimental air pump? wiarumas The Bar 10 11-29-2007 04:58 PM
WTB: Electric Air Pump (smog pump) MagnuM Mustang Parts for Sale and Wanted 0 05-16-2007 10:10 AM
water pump ? jumpman1203 Pre-2005 V6 Mustang 0 10-16-2006 12:25 AM
10:39 AM
