t-lok question - Mustang Evolution
Old 11-07-2006, 09:12 PM   #1
Send a message via AIM to BigL34461
t-lok question
ok.......i heard that 7.5 with 4.10's out of a ford ranger will work on the mustang v6 is this true? and what else do i need to get once i get them?
BigL34461 is offline   Reply With Quote
Old 11-07-2006, 09:43 PM   #2
Re: t-lok question
I know the rear end will work, I'm not, however, sure if the axle size is the same. You can use your factory axles if need be though, they will work in that pumpkin and be the correct width.
Old 11-08-2006, 08:22 AM   #3
Re: t-lok question
many have used the diff and gears from a 7.5 inch rear axle ranger. I cant remember if the offset axle size matters~ I dont think it does. I wouldnt put used gears in but thats just me (Ive tried to go the cheap way and wound up paying twice as much as doing it right the first time around... learned my lesson on rear end gears)
Old 11-08-2006, 09:56 AM   #4
rydog's Avatar
Send a message via MSN to rydog
Re: t-lok question
I have always had used gears installed and they have all been from ford rangers. My budy works at the Ford dealership and I get them pretty cheap $200 installed. I have never had a problem with used gears but its all in the install making sure the back lash is right, wear pattern, shims etc.
97 V6-GT40 turbo-42#rs-BA2800 MAF-4.10's & tlok-254rwhp-369rwtq
Turbo'd by-TMA Turbo(http://www.tmaturbo.com/)
Tuned by-Dyno Tuned Performance(http://www.dtpracing.com/)
rydog is offline   Reply With Quote
LOK question Stumper Pre-2005 V6 Mustang 19 05-17-2010 06:49 PM
t-lok tim11 Pre-2005 V6 Mustang 15 11-06-2005 05:07 AM
T-lok question I_luv_HP&trq Pre-2005 V6 Mustang 9 10-02-2005 11:58 AM
Another 4.10s and T-Lok question soon2bfastr232 Pre-2005 V6 Mustang 15 02-08-2005 08:38 PM
t-lok chevykiller Pre-2005 V6 Mustang 6 08-26-2004 02:35 PM
05:15 AM
