Have some ???s... - Mustang Evolution
Old 11-08-2006, 08:44 PM   #1
crazeflier07's Avatar
Send a message via AIM to crazeflier07
Have some ???s...
I have am looking into what my next engine mod is going to be and right now a SCT X2 or a Diablosport tuner is at the top of the list. If I added heads, an upper and lower intake, and cam with the chip what could I expect to gain in hp and torque? If I bought the tuner only and then later bought the other stuff would I be able to use the same tune or would I have to go and get a custom tune? If I didnt do the heads, intakes, and cam what would be a good mod to do with the chip? Thanks for any info.
~Jon~
Sinister Six
1998 3.8L V6
Done So Far:
~CAI, True dual exhaust, UDPs, MGW Shifter, H&R springs, Stage 1 & 2 supension kit, performance rotors & pads, steel braided lines, 1 inch rear spacers, A.R. Rebel 17x9s with BFG rubber! :thumbs2:
crazeflier07 is offline   Reply With Quote
Old 11-08-2006, 10:09 PM   #2
Re: Have some ???s...
If you are planning on doing gears/cam/other engine things, I'd recommend waiting and getting the tuner later and getting a good dyno tune. No need in buying a tuner with a tune on it now just to pay more later just to have it tuned again.
Old 11-09-2006, 12:53 PM   #3
Will I have to do something to calibrate my computer with the gear change? How much would I be looking at to get a custom tune done?
~Jon~
Sinister Six
1998 3.8L V6
Done So Far:
Old 11-09-2006, 01:54 PM   #4
for pre 99's you dont calibrate the computer to do anything with the speedometer readings, its controled by a gear. You can get a dallas speedcal and hook it up and set it however you wish for any tire/rim/gear size ratio (within reason) and its around 100 bucks.
Old 11-09-2006, 03:06 PM   #5
Will I have to get the speedcal or is the difference going to be so minimal that its not really worth doing?
~Jon~
Sinister Six
1998 3.8L V6
Done So Far:
Old 11-09-2006, 03:08 PM   #6
You will need the speedcal
Old 11-09-2006, 03:48 PM   #7
Damn, hmm there goes the budget limit for the rearend!
~Jon~
Sinister Six
1998 3.8L V6
Done So Far:
Old 11-09-2006, 03:51 PM   #8
Danger Dude's Avatar
You dont need a speed cal a $7 dollar little plastic gear.
Old 11-09-2006, 04:45 PM   #9
Oh, nevermind then. Where could I get the little gear? Does it come with a tlok or the gears? Thanks
~Jon~
Sinister Six
1998 3.8L V6
Done So Far:
Old 11-09-2006, 04:56 PM   #10
~Jon~
Wherever you order the gears and Tloc just have them throw in a 23 tooth gear for either a manual or a auto, I have a 23 tooth white one
Old 11-09-2006, 07:34 PM   #11
Gotcha, thanks bro!
~Jon~
Sinister Six
1998 3.8L V6
Done So Far:
Old 11-09-2006, 07:37 PM   #12
How much is it going to cost him to have the gear put in the tranny though?
Old 11-09-2006, 07:37 PM   #13
bbunt302's Avatar
The speedo gear is easy to change. It's the drive gear that you have to take the entire tailshaft off for.
Scary stuff.
Old 11-09-2006, 08:20 PM   #14
I have a shop by me BlowbyRacing that only works on mustangs and other fords and I have talked to them about doing it. They said it would be about 240 to 260 done and out the door for the rear. Sound like a good price or no? What would you guys recommend?
~Jon~
Sinister Six
1998 3.8L V6
Done So Far:
Old 11-09-2006, 08:25 PM   #15
bbunt302's Avatar
For a gear install... that isn't too bad of a deal. It's not the cheapest in the world, but I'd rather pay more to a shop that I trusted to do it right.
Scary stuff.
Old 11-09-2006, 09:58 PM   #16
Yeah the shop is knows their stuff when it comes to stangs so they are the most reputable shop I know around here for that kinda work. If everything goes good I may do my engine work there too but we'll see.
~Jon~
Sinister Six
1998 3.8L V6
Done So Far:
Old 11-09-2006, 10:14 PM   #17
Zim
You want to **** me?
Zim's Avatar
FYI, the 23 tooths is meant for 3.55's
3.73's will still have your speedo be off slightly with the 23 tooth.
I like toys
Old 11-09-2006, 10:23 PM   #18
That is why I got the Speedcal. My speedo would have been off still
Old 11-10-2006, 06:04 AM   #19
bbunt302's Avatar
Yup. With 3.73s you need a 21 tooth speedo with a 7 (I think, could be wrong) tooth drive gear.
Scary stuff.
Old 11-10-2006, 06:58 AM   #20
basically if you want to half *** it put in a speedo gear as it will not be accurate with 3.73 gears. If you want to do it right buy a speedcal. End of discussion.
I put a speedogear in my 97 v6 auto before I even knew of a speedcal and it was off, you will also be commiting a crime as your odometer will be registering fast.
with the speedcal you can alter it for rim/tire height and many things so you wont be tied to the overall diamter of the wheels/tires that the car had stock.
Old 11-10-2006, 11:29 AM   #21
ahhh....ok cool thanks!
~Jon~
Sinister Six
1998 3.8L V6
Done So Far:
11:12 AM
