Break in for new gears?? SCT tuner to change speedo?? - Mustang Evolution
Old 06-24-2010, 10:04 PM   #1
Hey Everyone,
Just got new gears for the 2010 mustang, 4.10s from 3.31 and went with the posi rear as well...Is there a "break in" period for the gears? I certain amount of miles must be driven in order to properly be able to use the gears? I have heard a million different things, any help would be great!! Also how the hell do I change the speedo using my SCT tuner? Can I do it manually or do I have to call SCT or AM?? If I can do it with my handheld on my own, then how? Thanks everyone! You guys always point me in the exact right direction!!
Camaro Eater is offline   Reply With Quote
Old 06-24-2010, 10:14 PM   #2
Re: Break in for new gears?? SCT tuner to change speedo??
Originally Posted by Camaro Eater View Post
Hey Everyone,
I was told a few hundred miles for a break in period. I have also heard go to the track and tear into it. But its better safe than sorry.
It depends if they left the tune open or not. When you select the custom tune, there should be a user changes option. It should let you select the gear ratio. Thats only if they left the tune open. They give free tunes for life so if you cant change it yourself, they'll do it for free. Good luck.
tigerfan2771 is offline   Reply With Quote
Old 06-25-2010, 06:10 AM   #3
hottcobra's Avatar
What was already said on the tune is correct. As for the break in. You need to drive 100 miles without going full throttle. And if it's mostly interstate you need to change your speed often I.E. Don't set the cruise.
Old 06-25-2010, 08:03 AM   #4
yea, get a few hot/cold cycles on the gears and you should be good to go. If you hear ANY whine on accel/decel/coasting take it back to the install its NOT (I repeat NOT) normal.
sct tuner dd96stang Pre-2005 V6 Mustang 6 04-09-2010 01:53 PM
speedo gears? Sassa Massa 1979-1995 Mustang GT 8 05-17-2007 09:35 PM
Speedo/Odometer Gears floridamba Pre-2005 V6 Mustang 5 05-01-2007 09:32 AM
speedo stuff with gears Sublime782 Pre-2005 V6 Mustang 5 05-29-2005 02:59 PM
Gears and tlok speedo correct Falcon Pre-2005 V6 Mustang 15 12-21-2003 07:54 PM
06:31 AM
