Need A Write-Up - Mustang Evolution
Old 11-11-2006, 02:50 PM   #1
Send a message via AIM to MyStangStanks
Need A Write-Up
Hey again...I need a write-up or instructions on how to install a SuperCoupe Supercharger on my 3.8 because I'm hopefully going to be getting one soon (knock on wood). Thanks In Advance
1995 Rio Red 'Stang
Mods-to-be: MAC 2.5" dual exit cat-back, CAI, UDP, 3.73 gears, Short Shifter, Tuner
Mods-after-that: Roots style blower, 8.8" rear end, Aluminum driveshaft, some other crap...
Goal: To have a sixer that beats V8's! :burnout:
MyStangStanks is offline   Reply With Quote
Old 11-11-2006, 04:10 PM   #2
rydog's Avatar
Send a message via MSN to rydog
Re: Need A Write-Up
I dont anyone in here has done a supercoupe swap I know a couple of guys on 3.8board have you can try searching there
97 V6-GT40 turbo-42#rs-BA2800 MAF-4.10's & tlok-254rwhp-369rwtq
Turbo'd by-TMA Turbo(http://www.tmaturbo.com/)
Tuned by-Dyno Tuned Performance(http://www.dtpracing.com/)
rydog is offline   Reply With Quote
Old 11-11-2006, 09:20 PM   #3
Re: Need A Write-Up
basically dont do it, they dont produce nearly enough HP/Tq to make it worth while. You should invest that money into a head/cam/intake package and MORE hp naturally aspirated.
Old 11-11-2006, 09:40 PM   #4
Zim
You want to **** me?
Zim's Avatar
Re: Need A Write-Up
well, they produce a ton of torque, but the HP is only around 210-220.
Defnitely not worth it.
Get nitrous instead.... seriously
I like toys
Old 11-12-2006, 10:11 AM   #5
Re: Need A Write-Up
plus the stock bottom end does not like a ton of psi so you will melt the pisons build the engine and make more hp and have a MUCH stronger engine.
Old 11-12-2006, 03:35 PM   #6
meteorachick's Avatar
Re: Need A Write-Up
my advice...if u don't know how to do it and u are planning on installing it yourself, DONT DO IT lol
Modified 2004 V6
Old 11-14-2006, 02:53 PM   #7
rydog's Avatar
Re: Need A Write-Up
My suggestion is do a lot of reading up and decide what you want to do with your car mod wise. A little more money and you could go with a supercharger or turbo and get much better results. Also you have a 95 single port that had a head gasket recall so adding any kind of power adder to your car without at least replacing the head gaskets is a bad idea:shake:
Old 11-15-2006, 07:25 PM   #8
Re: Need A Write-Up
Well I'm not going to be running a whole lot of boost, until I build the engine however...But it's the easiest way for me to get more power (which I'm in desperate need of) and I'm not spending anything on it, so I'm not complaining!
1995 Rio Red 'Stang
Old 11-15-2006, 08:23 PM   #9
rydog's Avatar
Re: Need A Write-Up
= not much more power
Old 11-16-2006, 02:47 PM   #10
Herbstang's Avatar
Re: Need A Write-Up
+ 1 !! You'd be better off with a bottle
Old 11-20-2006, 12:06 PM   #11
Re: Need A Write-Up
lol I'm trading an '87 MR2 that needs head work, a battery, and new full gasket set. That's why I'm not spending any MONEY, but yes, there willl be some kind of trade.
1995 Rio Red 'Stang
Write ups? 4to8 1996-2004 Mustang GT 3 05-16-2010 11:23 AM
I have decided to become a write-in candidate Herbstang The Bar 13 09-23-2008 09:56 PM
How to write good n8r The Bar 7 12-23-2006 10:38 PM
Write letterz n s***, yo! BlkStang4Me The Bar 15 06-26-2004 06:09 PM
10:13 AM
