need help asap!!! speedometer - Mustang Evolution
Old 06-26-2010, 02:56 AM   #1
Send a message via Yahoo to Senorjizzy
Exclamation need help asap!!! speedometer
while installing a new amp, i dropped the wire leading to the battery and it struck the alternator. and for some reason, the speedometer will not function. but the other gauges do.
i really need to fix this, its uncomfortable. its an automatic, so itll probably be harder. if i can fix it without using a shop ill be pleased
- Dusty
maroon 1998 mustang V6 auto. AM cai. Raxiom black headlights )
Senorjizzy is offline   Reply With Quote
Old 06-26-2010, 08:38 AM   #2
1234's Avatar
Re: need help asap!!! speedometer
First off check the fuses and relays. Happened to me and that was the fix. If that doesn't work. My buddy is a electrical engineer. I will ask him.
Old 06-28-2010, 02:31 PM   #3
how would i check the relays? one fuse was burnt, and after replacing nothing changed. so i hope its a relay
Old 06-28-2010, 03:58 PM   #4
hottcobra's Avatar
they don't have any relays for the speedo. If it's not a blown fuse. you will have to bring it to a shop. where they can use a scan tool to see if you are getting a signal for the speed sensor to the gauges.
Old 06-29-2010, 06:47 AM   #5
Zebs5408's Avatar
its electrical so gotta be fuses or relays....get a graph of of ur fuse diagram and go thru every single fuse man...i know ur like WHY....jsut do it lol
04' mustang 3.9 40th Anniversary Edition- (V2 Vortech Supercharger, 38# injectors, 3.73 gears w/ T-lok, Predator Diablo, Mac cold air intake, Port & polished upper AND lower intake manifold, Mac Long Tube Headers, Mac o/r H pipe, flowmasters, 2.5 flowmaster tips)
03' Mustang GT (20" Cobra R's, 40 series Flowmasters)
Zebs5408 is offline   Reply With Quote
3.73's installed ( need speedometer help ) big show 98 Pre-2005 V6 Mustang 8 12-25-2009 06:33 PM
help with speedometer roach 1996-2004 Mustang GT 2 06-20-2009 07:29 PM
v6 speedometer help. 01stang232 Pre-2005 V6 Mustang 5 01-13-2007 08:20 AM
speedometer issue.. MonteCitan 1979-1995 Mustang GT 3 08-15-2006 05:14 PM
speedometer project Tbird232ci Pictures and Videos 10 07-08-2005 11:16 AM
09:39 PM
