Need cam help - Mustang Evolution
Old 11-17-2006, 06:28 PM   #1
Need cam help
Looking at doing intakes/cam here soon. I'm wanting opinions/suggestions on what durations to look at and who is the best to talk to. I want you to know there is a cam in there at idle, but not to the point I'm hurting performance. Basically, the best idle with the best performance.
For background, I have CAI/Exhaust/EGR delete, extent of performance right now. Gonna be running 4.10's with this as well as an offroad x and 94-98 manifolds.
So basically, what specs would you recommend running for this setup? It's going to be this way for a while and I'd like to at least be able to do heads without changing cams, I'll be ready to change specs later on, just want this to be the best I can for my current setup.
Old 11-17-2006, 06:31 PM   #2
Re: Need cam help
Would something like a 214/214 duration, .48/.48 lift, 110 lobe be too much? lol
Old 11-17-2006, 11:47 PM   #3
dapack69's Avatar
Send a message via Yahoo to dapack69
Re: Need cam help
I use to own that cam your talking about. It sounded sweet at idle.
I have a bone stock steering wheel.
http://www.gotstang.com/profile.php?dapack69#jump
dapack69 is offline   Reply With Quote
Old 11-17-2006, 11:48 PM   #4
Re: Need cam help
what is cam. im not a big car expert.
mustang0386 is offline   Reply With Quote
Old 11-18-2006, 12:37 AM   #5
dapack69's Avatar
Re: Need cam help
Originally Posted by mustang0386 View Post
wat is cam. im not a big car expert.
Your not a big speller either.
A cam is the heart of the engine, you have it designed around the other things done to the car.
Old 11-18-2006, 09:26 AM   #6
Re: Need cam help
the cam turns and moves the push rods up and down. the push rods push up on the rocker arms which open/close the valves that let air in/out of the cylinders.
Old 11-18-2006, 12:56 PM   #7
Re: Need cam help
Camshaft - Wikipedia, the free encyclopedia
JROC is offline   Reply With Quote
Old 11-18-2006, 06:18 PM   #8
bbunt302's Avatar
Re: Need cam help
110 LSA sounds like quite a bit... I don't know about the 3.8, but with a 5.0 you can't expect a motor with a 110 LSA to really have much of an idle.
I'd look for something along the lines of a 112 or 114. For reference, I'm running a 114 LSA, .512"/.512" lift, 218*/224* duration cam in my car.
You also may really want to look into a cam that is split duration. Ford motors are notorious for having "less than healthy" exhaust ports, and therefore benefit from a little more duration on the exhaust side.
The lift sounds about right though.
Scary stuff.
Old 11-18-2006, 06:36 PM   #9
Re: Need cam help
Well how much would it hurt to do say heads and cam and leave the intakes for later. I know the car will be kinda starving up top with the stock intakes, but it will only be for a year tops. Just kinda seems pointless to rip the same part of the engine down twice.
Old 11-18-2006, 06:54 PM   #10
slvr2000stang's Avatar
Re: Need cam help
That would be ok.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 11-18-2006, 06:55 PM   #11
Re: Need cam help
What would you recommend kirk? I can either do gears/intakes/cam now or do cam/heads for now. Which would you do first?
Old 11-18-2006, 07:06 PM   #12
Re: Need cam help
cam/heads now imo. Get the hardest part (and most expensive) out of the way
Old 11-18-2006, 07:22 PM   #13
Re: Need cam help
The more I look at the powerpacks from supersix the more I like the stage 2+. I wouldn't be able to do gears for a while...maybe the 7.5 would hold up to that. Still kinda wanting recommendations on what I should be looking for cam-wise. Where's brother corey when ya need him, I liked the idle his car has.
Old 11-18-2006, 08:07 PM   #14
Re: Need cam help
I agree with Brent.
The 7.5 will be ok, I am still running one.
2000 Vert 4R70W
Old 11-20-2006, 02:29 PM   #15
rydog's Avatar
Send a message via MSN to rydog
Re: Need cam help
Yea I think the 7.5 will be fine they are alot stronger than people give them credit for. I had a 7.5 with 3.73's in my supercharged 82 5.0 and ran 28-10.5 mickeys with lots of track time and never had a problem however I wouldnt recomend it. as for as the cam I dont know if you are a 5-speed or auto taht cam would never work in an auto the 110lobe sep would bleed off to much compression at low rpm you def need something more along the lines of what b-bunt was saying about 114
97 V6-GT40 turbo-42#rs-BA2800 MAF-4.10's & tlok-254rwhp-369rwtq
Turbo'd by-TMA Turbo(http://www.tmaturbo.com/)
Tuned by-Dyno Tuned Performance(http://www.dtpracing.com/)
rydog is offline   Reply With Quote
Old 11-20-2006, 04:22 PM   #16
Re: Need cam help
I am running a 112 lobe sep on mine.
2000 Vert 4R70W
Old 11-20-2006, 07:33 PM   #17
rydog's Avatar
Re: Need cam help
Thats what I was running in my 82 5.0 with a 2800 stall converter
Old 11-20-2006, 09:18 PM   #18
Re: Need cam help
Tom from supersix has recommended a 218/224 112 lobe, how's that sound to ya'll? I'm still trying to learn all these cam terms.
Old 11-20-2006, 11:45 PM   #19
Kiljosh's Avatar
Re: Need cam help
I have a 216/216 112 lobe. A vid of my exhaust is in my gallery. It does have a lot of lope but pulls real hard above 3g's.
Old 11-21-2006, 08:44 AM   #20
bbunt302's Avatar
Re: Need cam help
Cam Truth
Scary stuff.
Old 11-21-2006, 07:29 PM   #21
97Stallion's Avatar
Re: Need cam help
Long term goals should be kept in mind here. The split duaration will give you a slightly loby idle and it geared more for supercharged engines. BUT, on the plus side a split duration all around is a great cam for N/A and SC'd. I have the 224/230 cam in my car and it's great. And also if you have too allow too much air into the engine but can't get out the air as fast you're going to lose power. EX. I stroked my engine to the 4.2 in 2003 and I went from 180rwhp to 168rwhp. Reason being my exhaust wasn't modified yet enough to handle the 4.2 and was slightly clogged and now i'm at 218rwhp since i fixed my exhaust. Now my other problem I need a new intake manifold that will allow more air into the engine to get me up to about 240rwhp or possibly more. ::sigh::
Living one day at a time!
Old 11-21-2006, 10:13 PM   #22
Re: Need cam help
Well I talked to Tom up at supersix and he recommended that one since I'm looking at possibly stroking in the future and supercharging. With these future mods in mind that is a fairly rounded cam. As far as moving the air out, I have an offroad X sitting in the kitchen and a set of 94-98 manifolds and my mufflers are pretty straight through, if nothing else it'll be flowing too much. I'm definitely trying to build for the future.
Which Cam? b's stang 2005-2010 Mustang GT 2 07-18-2010 10:25 PM
3.8 V6 Comp Cam Performance Cam nmaraijko Mustang Parts for Sale and Wanted 0 11-15-2006 07:11 AM
Cam Cores needed for RDMotorsport cam GP RGR Mustang Parts for Sale and Wanted 3 03-05-2005 05:53 AM
cam and rr? cjd10 Pre-2005 V6 Mustang 16 02-08-2005 04:12 PM
05:57 AM
