how do you............... - Mustang Evolution
Old 11-26-2006, 02:34 PM   #1
reprogram the door unlock remote?
and do you have to go to the dealer to make a spare key?
ryanxup is offline   Reply With Quote
Old 11-26-2006, 02:42 PM   #2
Re: how do you...............
You can reprogram the remote...but I really don't remember how, I'll do some research, and as far as the key, you have to go somewhere that can program the key, which I believe may only be Ford.
Old 11-26-2006, 02:45 PM   #3
Here ya go, how to program remote entry.
Programming Mustang Keyless Entry Remotes - Stangology Mustang Forums
Old 11-26-2006, 02:55 PM   #4
thanks
Old 11-26-2006, 02:57 PM   #5
Also, I found this on programming keys, dunno if it works, but sounds like it would.
Originally Posted by svtperformance
Spare Key Programming Procedure
Two electronically coded keys were supplied with your vehicle, use one of these with the procedure below:
- Using a coded key that you can start your engine with, turn the ignition from the ON to the OFF position.
- Within 15 seconds, insert a new key into the ignition and turn it to ON or START. The vehicle does not have to be started.
If the key has been coded, the theft indicator will illuminate for two seconds. The key can then be used to start the vehicle.
Repeat until all chosen keys have been coded (max=16).
If the key coding failed, the theft indicator will flash and the vehicle cannot be started. One of 3 causes are possible:
- The new key was not inserted within 15
seconds or
- All 16 key codes have been stored or
- The key does not have an electronic code
Old 11-26-2006, 03:11 PM   #6
MonteCitan's Avatar
The above works.. except -->> I have NOT been able to do that with any less than 2 pre-programmed keys..
cycle first programmed, remove first, insert second and cycle second.. then remove and insert unprogrammed key, and cycle it..
If we only had one programmed key, we'd had to hook up the computer and run through the 10 minute PATs access...
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 11-26-2006, 03:34 PM   #7
Can you program a key to work on two vehicles, or will it erase the old information when you reprogram it for the new vehicle.
Also, can't you program a keyless remote to work on two different cars?
Old 11-26-2006, 05:46 PM   #8
MonteCitan's Avatar
It will erase the old vehicles and just program the new one assuming the key would work..
Old 11-26-2006, 07:13 PM   #9
how much does it cost to program the key if you went to the dealer
Old 11-27-2006, 09:27 AM   #10
Herbstang's Avatar
Cost should be between 70.00 to 120.00 depends on the dealer ,I just paid 72.00 for my girl friends key .But I was quoted as high as 160.00
11:41 PM
