squeel/squeek - Mustang Evolution
Old 07-04-2010, 11:20 AM   #1
epd418's Avatar
squeel/squeek
new mustang owner 04,3.8l has a intermintent squeel / screech. Belt was worn and top small center pulley replaced both. still makes same noise not as often .mostly at idle any help.newbe big time
epd418 is offline   Reply With Quote
Old 07-05-2010, 05:47 AM   #2
Tape's Avatar
Re: squeel/squeek
pull off the belt and run the car, also hand spin the pullies, you can feel if one is bad
Tape is offline   Reply With Quote
Old 07-05-2010, 07:18 AM   #3
Re: squeel/squeek
Hmmm....could be off here but I've heard many of power steering pumps do some squeeling like that. Not sure though, did you replace the belt yourself? If you had your mechanic do it, I would suggest taking it to him with the issues. Just my two cents, good luck.
Camaro Eater is offline   Reply With Quote
Old 07-05-2010, 07:36 AM   #4
epd418's Avatar
Re: squeel/squeek
did the belt myself twice now getting good at that going to take the belt off again and turn the pullies this moring. I have had bad power steering pumps on other cars, it does not sound like its comming from there but will add it to my list of things to check
thanks
Old 07-06-2010, 04:29 AM   #5
Send a message via Yahoo to DDavis30
Re: squeel/squeek
Belts squeel cuz they're loose... check the condition of your pulleys (rust, pitting, wear,damage,etc), Replace anything that looks worn out in any way... if they look good, replace the auto tensioner assembly... sounds to me like the spring on the auto tensioner might be a little weak ... Also... I agree with Tape .. spin everything by hand .. you can definitely feel a bad pulley bearing ..
2004 V6 Mustang
2006 Pontiac Torrent
1990 Nissan 300zx
1999 Suzuki Intruder 1400
DDavis30 is offline   Reply With Quote
fixed the squeek epd418 1996-2004 Mustang GT 3 07-13-2010 10:04 AM
05:46 PM
