1994 V6 to 1999 GT V8 swap - Mustang Evolution
Old 12-08-2006, 12:56 PM   #1
Send a message via AIM to alienyouth736
I have a 1994 Ford Mustang V6. I found a wrecked 99 GT with the 4.6L V8 for cheap. I want to drop the V8 into the V6 because the V8 is pretty bad but the engine is in running condition? Everything I need should be on the GT already cause the main things I'll need are
-Engine
-Tranny
-Computer
-Rear end
Any tips, pointers and suggestions are greatly appreciated!
alienyouth736 is offline   Reply With Quote
Old 12-08-2006, 01:09 PM   #2
bluemustang's Avatar
Re: 1994 V6 to 1999 GT V8 swap
dont forget your gonna need all the little items like taking the cluster out and that whole ordeal.
I forgot what else but i think your gonna have to swap out the whole fuel system that whole returnless thing.
not a 100% sure
good luck though
Old 12-08-2006, 01:53 PM   #3
be ready for a nightmare, its never as easy as it seems. You will need the computer and you will have PATS issues (ignition system/computer/cranking car/using your current key/issues)
Old 12-08-2006, 01:54 PM   #4
ANd you will need the K member
Old 12-12-2006, 03:15 AM   #5
Region: Hawaii
You will need everything they said, and also the Hydrobooster system.
99 Atlantic Blue V6- SOHC 4.6 swap, Tremec 3650, 8.8 rear end/ Flowtech Ceramic LT headers, off-road x-pipe, Spintech side exit exhaust. K&N drop in filter, removed snorkel, 18x10, 18x9, Anthracite Bullitt Replicas 295-35's, 265-35's. Eibach Pro-Kit springs, M&M Camber Plates
wrecked2001 is offline   Reply With Quote
Old 12-16-2006, 10:36 AM   #6
Fishers Stang's Avatar
thing to keep in mind, its a lot better to take a v8 out of a close to the same year as urs.. I wanted to do a swap but its a lot of money. Wrecked2001 did one on his, but he put the V8 in the same body as the wrecked one (01 engine in a 99) u will need a 2nd car also during the down time
Charles
Old 12-24-2006, 11:04 PM   #7
Don't forget about suspinion stuff, I am pretty sure the v8 and the v6 will have diffrent spring rates and what not. Or else it will ride like a pig
3.3Liters4Fun is offline   Reply With Quote
Old 12-27-2006, 03:28 PM   #8
nope v6 & gt have same stuff for the most part,
Charles
1999 3.8 swap to 5.0? snake428CJ 1979-1995 Mustang GT 26 06-22-2017 12:40 PM
Is it actually a 1994? winterwolf Pre-2005 V6 Mustang 8 01-24-2010 10:35 AM
1994 V6 SVTCOBRA Pre-2005 V6 Mustang 7 12-25-2006 06:24 PM
1994 v6 parts mustang302_94 Mustang Parts for Sale and Wanted 0 09-22-2006 09:27 AM
1996 Mustang 3.8 to swap to 1999- 2004 3.8 NewkidonDblock Pre-2005 V6 Mustang 5 05-30-2006 09:17 AM
03:57 AM
