RPM dips - Mustang Evolution
Old 10-15-2003, 09:04 PM   #1
wiarumas's Avatar
RPM dips
i just noticed (i think it just started to do this for about 3 weeks now)... at idle.. my car dips and rises in RPMS every few seconds. it will be at 700 and then it will dip down to 600 and then rise up to 800. my exhaust makes a puffing noise too.. and you can feel vibrations while sitting in the car too when it does that. it only does it on a warm engine too... im thinking maybe its just my exhaust setup or maybe its something more serious? bad fuel injector maybe? it might not even be a problem.. maybe its normal? to be honest.. i kinda like the sound of it.. however... i wanna know if something is messed up.
Old 10-15-2003, 09:07 PM   #2
Send a message via Yahoo to mustangmeat
my 99 does it too. i am gonna change the plugs and wires and see if it helps. i hear the fuel pump/delivery system could be to blame
mustangmeat is offline   Reply With Quote
Old 10-15-2003, 09:23 PM   #3
Black95GT's Avatar
Send a message via AIM to Black95GT
my car does it when my Bass hits I need a powerful alternator though
-Jason
2003 DSG Cobra -2.2L KB, 60lbs Injectors, Single Blade TB, SCT2400 MAF, Kook's LT's, Kook's High-Flow Catted X-Pipe, Magnaflow CB, JLT RAI, MGW Short-Throw, H&R Race Springs, MM CC Plates, MM Bumpsteer, BF IRS Brace, BF Idlers, and AFS 18 Chrome Reps w/ R888s
Black95GT is offline   Reply With Quote
Old 10-15-2003, 11:27 PM   #4
Send a message via AIM to whipster24 Send a message via Yahoo to whipster24
My car does the same thing, plus I get a nice high pitched whine at the rear end that I'm guessing comes from the fuel pump.
"This year will go down in history. For the first time, a civilized nation has full gun registration. Our streets will be safer, our police more efficient, and the world will follow our lead into the future!"
-Adolf Hitler, 1935
whipster24 is offline   Reply With Quote
Old 10-15-2003, 11:29 PM   #5
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
yup myns been doing that, then the fuel pump died, iam in the processes of fixing myn. My car currently doesnt have a gas tank. Ill get the tank and new pump up tomorow.
Rellik is offline   Reply With Quote
Old 10-15-2003, 11:51 PM   #6
Oh lovely, Yeah, the guy at napa said that it might be no problem cuz some fuel pumps tend to whine anyway. I know it's not the plugs, I just changed those a few weeks ago.
-Adolf Hitler, 1935
Old 10-15-2003, 11:54 PM   #7
I thought I wasn't getting the fuel efficiency that I should be getting.
I wonder if this pump would work well?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=6763&item=2436868799
Ya think something off of ebay would be a good choice?
-Adolf Hitler, 1935
Old 10-16-2003, 06:15 AM   #8
Monkey's Avatar
that fuel pump is too much money. 190lph's usualy goto for like $90ish.
all you really need is like a 155lph. www.summitracing.com or www.jegs.com
Old 10-16-2003, 08:26 AM   #9
most of the 155s I've seen are running around $85 or so on those sites.
-Adolf Hitler, 1935
Old 10-16-2003, 08:32 AM   #10
Here we go
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2437111747&category=33555
-Adolf Hitler, 1935
Old 10-16-2003, 08:38 AM   #11
iam getting a 255lph
and a fuel regulator. Do I need a fuel regulator if iam running a 255 monkey?
Old 10-16-2003, 08:50 AM   #12
Danger Dude's Avatar
no you dont need a regulator unless you change injectors. your current stock fixed regulator will regulate the fuel just fine. the fuel pump is major overkill unless you are going for big time poweradder
Old 10-16-2003, 09:10 AM   #13
Yes a power adder will be in the future.
procharger, you should know this corey! my car is a big project! lol
Old 10-16-2003, 09:11 AM   #14
ps how long do fuel pumps last for?
Old 10-16-2003, 09:28 AM   #15
Monkey's Avatar
you can never have too much pump. like corey said, it will get regulated by the regulator and the injectors.
but the larger the pump, the less life it has. they are good for a while though, and never that expensive
Old 10-16-2003, 09:28 AM   #16
Well that is a tuff one. Normally they have a long life. You have a 95 so that is 9 years I know quite a few mustangs that have the original pumps
Old 10-16-2003, 09:30 AM   #17
My original pump just went.
Matt'sdrag95 gave me his old gas tank, and it has his pump in it which was good.
My tank was very rusted so i painted a few posts on his so it wouldnt rust as bad and iam just going to swap tanks.
Right now all i gotta do is put on the new tank and iam done.
Old 10-16-2003, 12:25 PM   #18
Zim
You want to **** me?
Zim's Avatar
how much work is it to change the fuel pump? is it actually inside the tank or can someone take a pic of where its at? I need to get a 155lph pump so i can run 100 shot soon here.
I like toys
Old 10-16-2003, 01:09 PM   #19
its not hard,
Syphon gas tank.
Remove all bolts to the filler neck.
Remove all bolts on the gas tank straps.
get a jack with a long piece of wood on it, before u take off the last bolt.
Then take off the last bolt, lower the jack, wiggle out the filler neck from the tank.
Go a little lower. (hard part) removing the fuel lines, you gotta get a fuel line disconnect set, got myn at sears it was 9.99.
Its a *****, myn was all rusted. Very hard to get them off.
But once their off, unplug the gas pump harness.
Lower the tank.
Then the fuel pump assembly is right to the right. (near where the filler neck goes)
Dan haga made a write up on swtiching fuel pumps somewhere
Old 10-18-2003, 06:21 PM   #20
Oh sure, and the check engine light just came on!
-Adolf Hitler, 1935
Old 10-18-2003, 06:42 PM   #21
Monkey's Avatar
goto Autozone and get it read for free. it will tell you whats wrong
Old 10-18-2003, 11:16 PM   #22
RPM Tips
Yeah, I saw that in the tips/tricks.
-Adolf Hitler, 1935
Old 10-19-2003, 03:27 PM   #23
Send a message via AIM to el cheapo
yeah you think thats wierd my car idle dips when i mash on the brakes. . . super wierd :
damn it school, why do you suck so bad??
el cheapo is offline   Reply With Quote
Old 10-19-2003, 06:50 PM   #24
You know If your cars RPM wants to dip when you mash on the brakes you might have a vacume leak or a failing brake booster
take off RPM NotoriousSPG Pre-2005 V6 Mustang 3 08-12-2006 07:48 AM
RPM Problem whitev6stang03 Pre-2005 V6 Mustang 6 01-20-2006 05:52 PM
Peek hp rpm? SeadudeRXP Pre-2005 V6 Mustang 12 12-12-2005 01:53 PM
RPM Outlet mustangmike524 The Bar 41 04-14-2005 10:39 AM
08:51 PM
