Tranny - Mustang Evolution
Old 12-21-2006, 11:52 AM   #1
megax29's Avatar
Send a message via AIM to megax29 Send a message via Yahoo to megax29
Tranny
My cars got 86k 04 automatic 3.9l. I bought my car new w/ 14.00 miles and I haven't change my trans oil. Is this something I can do...any tutorial/guide out there? Anything I should know? Are trans oil coolers worth the buck? Did I take to long to change it? What is the model that I have? Is it 4r70w (something like that) or the AOD or the AODE or are all these the same...please explain. Thanks
V6 Midnight Black
CAI w/ K&N Filter, Tokico Complete Suspension kit, Single Flowmaster w/ turndown, GT rear sway bar.
megax29 is offline   Reply With Quote
Old 12-21-2006, 12:48 PM   #2
Re: Tranny
wow, 84k on the stock fluid... lol you should change it in an auto every year (people on here probably think every other year but whatever...)
When you flush it flush ALL OF IT. You will have to drain the TQ converter to get it all. This means you will probably have to suck it up and get someone to do it. To just drain/fill you pull the pan and let it drain out (no drain plug ftl...) just back off all of the bolts a tad then back off the ones on the back (if the front of the car is jacked up) and let the fluid drain out of the back end.
Once trained remove the pan and change the filter. Put the pan back on and fill her up. Turn the car on cycle through all of the gears a few times as it takes a bit to get the fluid going so the car will change gears. It takes a good bit of fluid as well.
Heat is the number 1 killer of autos so a good trans cooler upgrade will be a nice item.
Old 12-21-2006, 01:15 PM   #3
bluemustang's Avatar
Re: Tranny
B&M makes some good tranny coolers thats what Ive always bought personally
Old 12-21-2006, 02:59 PM   #4
Re: Tranny
ive heard that every 20 degrees cooler your trans is it can double its life~
Old 12-21-2006, 03:12 PM   #5
Re: Tranny
really see who says you dont learn something new everyday
Old 12-21-2006, 10:15 PM   #6
Re: Tranny
My local ford dealer does a complete flush for 120 out the door. Not too bad, and it saves me the trouble. I would definitely recommend getting a complete flush, especially with that many miles.
Old 12-22-2006, 12:15 AM   #7
Re: Tranny
I have a B&M Tranny Cooler. Works great. Never had a problem with it.
Old 12-22-2006, 11:55 AM   #8
Re: Tranny
and they want to charge me that much to flush my damn manual WTF is that its EASIER and CHEAPER to do than an oil change... pull to plugs put one back in put fluid in and put the other in....
Old 01-04-2007, 10:25 AM   #9
megax29's Avatar
Re: Tranny
I had it done for 20 bucks. The guy just unbolted the pan off, let it drain, put filter and that was it. Pretty easy I'll do it myself next time and I'll definitely not let it go that far next time. I don't think it was a complete flush where you drain the oil out of the torque converter. I didn't do it cuz the guy at the auto supply shop said if it were for maintenance I would need 5 or 6 quarts. It used up 5 1/2 quarts.
V6 Midnight Black
Old 01-04-2007, 11:20 AM   #10
Re: Tranny
I just dont have the space to do such things nor jack or jack stands etc
How to tell what tranny I have? Foxone Pre-2005 V6 Mustang 3 10-10-2009 10:12 AM
tranny help prive 1979-1995 Mustang GT 3 01-17-2009 10:44 AM
c4 tranny ryanxstang Pre-2005 V6 Mustang 11 08-20-2008 04:53 PM
tranny fsst93gt Regional Mustang Discussion 1 02-02-2006 03:08 PM
What Tranny? Smokedya95stang Pre-2005 V6 Mustang 7 03-20-2004 05:06 PM
12:08 AM
