CAI cleaning ??? - Mustang Evolution
Old 12-22-2006, 01:43 PM   #1
CAI cleaning ???
I recently bought an ebay CAI. How do I clean it and how often?
dshultz88 is offline   Reply With Quote
Old 12-22-2006, 01:57 PM   #2
Re: CAI cleaning ???
well basically you clean the air filter and reoil it every so often, once a year or so.
After you reoil it drive it for a day then take out the MAF and clean the sensor with ON CONTACT NO RESIDUE electronic parts cleaner. Then drive it a couple weeks and do it again. The gunk from the oil will get on the sensor and make your car idle bad etc etc.
Old 12-23-2006, 05:38 AM   #3
slvr2000stang's Avatar
As he said a No Residue Electrical Contact Cleaner.
If you have a plastic MAF housing get the one that is "Plastic Safe"
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 06-21-2007, 09:36 AM   #4
wher can u get that
millastang is offline   Reply With Quote
Old 06-21-2007, 09:37 AM   #5
Herbstang's Avatar
Any auto parts store should carrry CRC
Old 06-21-2007, 09:38 AM   #6
rydog's Avatar
Send a message via MSN to rydog
Your local auto parts store
97 V6-GT40 turbo-42#rs-BA2800 MAF-4.10's & tlok-254rwhp-369rwtq
Turbo'd by-TMA Turbo(http://www.tmaturbo.com/)
Tuned by-Dyno Tuned Performance(http://www.dtpracing.com/)
rydog is offline   Reply With Quote
Old 06-21-2007, 09:38 AM   #7
rydog's Avatar
Herb you ninjad me
Old 06-21-2007, 09:46 AM   #8
Herbstang's Avatar
Sorry !! The life of a Net Admin is slow when everything is workin
Old 06-21-2007, 10:31 PM   #9
TafoyaMNAA's Avatar
I was told to use Carb Cleaner for the MAF and it worked fine for me, car still runs strong, and idle is back to normal once i cleaned the MAF.
1999 Atlantic Blue Mustang Convertible V6 Auto - V-Force Mufflers w/ true Dual Exhaust setup, Dynotune Wet Nitrous Kit, B&M Tranny Cooler, B&M Shift Kit, BBK CAI, and T-Lok.
TafoyaMNAA is offline   Reply With Quote
Old 06-22-2007, 06:39 AM   #10
Herbstang's Avatar
Then you were given the wrong info
The Mass is a very delicate sensor. It uses two wires to measure the amount of air flowing into the engine. The two wires are heated (by electricity) and the more electricity used to heat them tells the ECU how much air is flowing past them.
Between very fine dirt and the trend towards oiled filters it's very important to clean the MAF. Cleaning the MAF has so many benefits it's unreal. Between reducing pinging, increasing mileage, and preventing it from burning out (saving yourself $$$) there's no reason to not clean the MAF sensor once every 6 months. Also clean it shortly after installing or reinstalling an oil filed.
You don't need many tools. As a matter of fact, and the pictured stuff is all you'll need:
You'll need a flat head screwdriver. Those are Safety Torx or Tamper Proof Torx bits. You can buy a whole set like I did or just get size T-20.
Now, it's time for an important note. You see that big red aerosol can? It's ELECTRICAL CONTACT CLEANER. This is the only thing you should use to clean your MAF. Only ELECTRICAL CONTACT CLEANER. No windex, no brake cleaner, no rubbing alcohol, and no Q-Tips.
Old 06-22-2007, 09:39 AM   #11
TafoyaMNAA's Avatar
Oh man i hope i didnt screw up that sensor. I'll go get some of that cleaner today and clean it agian thanks bro
cai
afe stage 2 cai or C&L racing cai b's stang 2005-2010 Mustang GT 5 05-20-2010 06:25 PM
cleaning out garage, come look. sledgehammer Mustang Parts for Sale and Wanted 24 01-27-2010 10:43 PM
Cleaning CAI SC_STEEDA Pre-2005 V6 Mustang 10 08-08-2008 02:15 PM
CAI cleaning dshultz88 Pre-2005 V6 Mustang 2 10-14-2007 09:40 AM
cleaning help!!!! millastang Pre-2005 V6 Mustang 3 06-21-2007 09:39 AM
02:21 PM
