Help, PATS is driving me crazy!! - Mustang Evolution
Old 10-16-2003, 10:01 AM   #1
Rick0636's Avatar
I was supposed to have my car in for an alignment this morning at 10 am, here I sit at almost noon, the thing won't run, stupid PATS thinks I am trying to steal my car I guess. It starts, then shuts down, seems to be shutting the fuel system down! What can I do here, HELP!! Any one know?
Old 10-16-2003, 10:03 AM   #2
Danger Dude's Avatar
did your key battery die and it does not recognize it anymore
Old 10-16-2003, 10:14 AM   #3
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
Call ford, see if theres anything you can do to get around it.
Rellik is offline   Reply With Quote
Old 10-16-2003, 10:32 AM   #4
Rick0636's Avatar
I have 2 keys, don't think the other will work either, but will try it again. Called ford, to reprogram PATs is 70 dollars, that is if it didnt' burn out some kinda module, ouch.
Old 10-16-2003, 10:46 AM   #5
Monkey's Avatar
its not PATS. if it were PATS, the ECU wouldnt even send a signal to the starter and let it start.
go in the trunk, see if the fuel cutoff switch has been turned off accidently. thats what it sounds like. sounds like the engine isnt getting the fuel, and is just getting enough from whats in the fuel lines, then shutting off.
Old 10-16-2003, 10:46 AM   #6
are your dash lights working
Old 10-16-2003, 01:15 PM   #7
Rick0636's Avatar
Was getting fuel, it flooded. The dash lights were working fine. It finally decided to start and run. Got my front end aligned at a different shop, got someone's appointment that didnt' show up. Still not sure what caused all that mess this AM, it took me til about 1PM to get it to start, I had to recharge my battery.
Old 10-16-2003, 01:16 PM   #8
Rick0636's Avatar
Oh, and I had already checked that switch in the trunk, it was not kicked.
Old 10-28-2003, 12:35 AM   #9
Send a message via AIM to ASSEMbler
Sounds exactly what I had a problem with. Was the wiring harness. Cost me $1600 to fix.
SIG REMOVED FOR THE PRUDE
ASSEMbler is offline   Reply With Quote
Old 10-28-2003, 07:41 AM   #10
Rick0636's Avatar
I found out what the problem was. My chip had a factory defect, it didn't show up until the weather started to get a little cool. Reinhart is making me a new one, I sent him the original one Saturday. With the chip out it starts on cool mornings and runs fine.
Old 10-31-2003, 05:02 AM   #11
Wow at least it was a easy fix !!!!
How 'bout them Pats? 04MonteSS The Bar 33 01-23-2008 08:53 AM
PATS system natebest2000 Pre-2005 V6 Mustang 10 03-03-2005 01:26 AM
pats pats pats! Rellik The Bar 14 08-08-2003 05:04 PM
06:54 AM
