Swapping brakes - Mustang Evolution
Old 10-16-2003, 10:34 AM   #1
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
Swapping brakes
Theres a fox body salavge yard in chester which is 20 minutes from my house.
He has tons of parts.
He has a ton of 8.8 rear ends with all kinds of different gear ratios for like 200 bucks!
My question is, Their 4 lug. I know id have to switch over the brakes, but is that easy? hard?
Anyone do this? Is there a how-to anywhere so i can read up on it?
Thinking i might do this.
Rellik is offline   Reply With Quote
Old 10-16-2003, 10:43 AM   #2
Monkey's Avatar
you have to swtich brakes and axles.
swapping brakes is just taking the caliper off, the rotor, and the dust shield if desired. then you just re-attach them to the new axle and plop that bad boy in the carrier. you could prolly even do it w/o having to disconnect the brake lines so you wouldnt have to bleed the brakes.
Old 10-16-2003, 11:24 AM   #3
Danger Dude's Avatar
Hey Monkey I am not absolutely sure but think the Fox body rear end setup is narrower wheel to wheel. You might need to use different axles
Old 10-16-2003, 12:18 PM   #4
You'll also have to buy two types of wheels if you ever buy new ones. That could get annoying. There may be more involved in this than you think
Old 10-16-2003, 01:10 PM   #5
why would i need 2 types of wheels?
Old 10-16-2003, 01:12 PM   #6
BlueDonkey's Avatar
I think the assumption you're keeping the fox 4-lug axles....
BlueDonkey is offline   Reply With Quote
Old 10-16-2003, 01:59 PM   #7
no, thats why iam going to swap brakes and what not. lol
Old 10-16-2003, 03:30 PM   #8
Monkey's Avatar
ok, i had a fox body rear in my car. its the same exact width from 84 (first year they made 8.8s) up to 98s. so it will bolt up just fine and look just the same you have now. you can get a 99+ which is 1.5" wider if you want the rear gaps filled out some. looks halfway decent, but theyre gonna be more expensive.
so no, you dont need different axles. his stock ones will be fine (granted theyre in good shape and the heat shield on them is still good). his stock brakes are the same ones they have been using for SN95s in GTs and 6'ers. it will just bolt right up.
no need for second set of wheels. your stock one will be fine as long as you re-use your stock axles.
Old 10-16-2003, 03:35 PM   #9
OK I dont know much about the fox body swap. I just remember reading something in passing about all the different rear ends
Thanks for the info Brandon
Old 10-16-2003, 03:41 PM   #10
Monkey's Avatar
:thumb2: thats what im here for
Old 10-16-2003, 03:45 PM   #11
See even at 43 years I can learn from the smart young ( Admittedly the wrong school) college guys !!!!!! 8) 8)
Old 10-16-2003, 07:06 PM   #12
Ha sorry about that earlier post. I'm out of it today. Been wrong about everything I've tried to do. Oh well. Thanks for correcting me though. I'll always take positive corrections and comments. My mind just isn't with me today.
swapping a 96 mustang 3.8 with a 2002 3.8 deerslazer Pre-2005 V6 Mustang 6 07-22-2010 01:03 PM
Help! Swapping a 2004 4.6 into 1996 HELP! fast8750 1996-2004 Mustang GT 0 07-03-2009 04:55 PM
swapping an 8.8 diff to a 7.5 rearend??? twin9mils 1979-1995 Mustang GT 6 03-26-2009 10:26 AM
swapping a C5 505danielm Pre-2005 V6 Mustang 2 01-05-2009 12:28 PM
swapping the rear from the 90 into the 64? fast64 Classic Mustangs 8 04-27-2006 10:13 PM
03:32 AM
